Old 04-09-2003, 12:49 PM
scottsubarus's Avatar
scottsubarus scottsubarus is offline
Scottsubarus
buying a 92SVX....advice?
We have 4 Subarus in our family and I have worked at a Subaru dealership in the early 90's
My son found a 92SVX AWD Black. locally. The price is 2,500 and it has 128K miles. I now work for a major transmission remanufacturer and know how the trannies have problems. The tranny has been replaced already with a SOA reman unit. I'm not sure if an addl cooler has been installed yet (we will if not) It has had dr side rear wheel brg replaced. The other things we found amiss are:
Climate control is stuck, all air comes out a/c ducts. We can hear the accuator trying to move the doors. The car has an aftermarket radio installed, we think it might be jammed on a rod or something.......any other ideas???
The fuel gage erratic, moves accross the dial slowly up and down
P. steering leak...drips off the dr side by the tire
Car overall is in great shape! and drove and shifted well. He had 2 SVX's for sale (another 92) he bought this one to take the engine out of it and install in a V/W vanagoon to replace a XT6 engine he has in it now!
Anyway what might be some other things to inspect and look out for??
Thanks!
Scott
Old 04-09-2003, 02:15 PM
subafan subafan is offline
not just a fan, a Member!
he bought this svx to swap out the motor..... so does that mean the svx has a xt motor now?
other than that.... assuming that if you work at a major tranny remanufacturer means you can do all the work yourself, or have them done affordably.... the car sounds ok to me.... maybe check rotors??
svx: the most effective diet (distant memory)
mr2: diet on the diet (on the chopping blocks)
urs4: looks stale, but good performance... hoping this one will last.... but too bad it didn't
mrspyder: gotta have a drop top in cali...
always looking for a reliable 5spd svx...
Old 04-09-2003, 02:23 PM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
Will reply when I get back from a testdrive.
L
Lwin M. Maung (Member # 147)
Current SVX: NONE
Old 04-09-2003, 02:32 PM
Green1995SVX
I think he means he bought it to swap out the motor, but then never did.
Mike
Old 04-09-2003, 02:53 PM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
Re: buying a 92SVX....advice?
Originally posted by scottsubarus
Climate control is stuck, all air comes out a/c ducts. We can hear the actuator trying to move the doors. The car has an aftermarket radio installed, we think it might be jammed on a rod or something.......any other ideas???
Most likely the foam seals on the door are full of oily goo causing them to stick. A small extra finger pressure on the arm will usually cure that until next summer.
The fuel gage erratic, moves across the dial slowly up and down
Most likely a fuel level resistor inside the tank. Just use the Odometer and fill up every 300 miles. I can't find a part number for the resistor itself and the whole pickup assembly is $150.00
Driver's side is Tranny lines. Passenger side has the Power Steering lines. By the tire are the two hoses from hell that connect the metal lines of the tranny to the metal lines of the engine runner. They are only a few inches long, but you need two people to get the clamps off. One underneath with about 3 or four 6" extensions and another at the top to hold the socket onto the clamp while its being turned by first person. When I swapped my engine last month, those two little hoses removing and re-installing were the most time consuming part of the entire process.
Doug
1994 LSi (4/93)
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Old 04-09-2003, 09:10 PM
Scottsubarus
Got the car tonight and had one major problem on the way home. Stopped for gas and car woulden't restart (no crank) because of the security system. After slamming the trunk hard car started. My question: what can we do to disengage the security system so it has no effect on the starting of the car.
Scott
Old 04-09-2003, 09:16 PM
Scottsubarus
The guy had a XT6 engine in his VW van. Looked like a nifty install!! goes to show anything is possible.
The SVX has sluggish power steering assist, assume it must be a rack assy. and it feels like struts need replaced too. Time and money is all she needs!!
Scott
Old 04-09-2003, 10:08 PM
alacrity024
make sure the PS belt is tight.. a couple cranks on that nut can to wonders for the ease of the steering..
-adam
