Old 03-20-2003, 02:53 PM
calmone
Unhappy parts help!!!
radiator is cracked!! subaru parts.com says $350.00. anyone know of availability of less expensive radiator availability?????
Old 03-20-2003, 03:10 PM
jsvxstyle jsvxstyle is offline
MINEZ BETTER
there is none. use o.e. only
replace coolant with mercedes benz coolant. its only for aluminum blocks, and heads.
white leathers, h.i.d, ecutune S/C stage 4, 14 inch 2piece rotors big brake kit., , msd ignition, c/f dash kit, front spoiler,carbon fiber jdm rearc wing,19 inch rims, nos, , aem fuel regulater, koni-gc package, ported cylinder heads, supercharger cams,solid buck and shims,wrx sti intake valve and exhaust valves,& valve springs, gas analizer,water injection, exhaust temp gauge, idiglo gauges, shift kit, , remote start, all automatic windows,2.5 inch true dual exhaust system with crossover, and 2 borla stainless steal muffler,air filter velocity air stack 3inch to 6 for air filtre, group n mounts, momo steering wheel, dyno will happan soon
Old 03-20-2003, 03:18 PM
JLittell
Look for a used one. I'm sure someone is parting a car out in here.. $327.00 at
https://www.1stsubaruparts.com/part_number.html
Old 03-20-2003, 07:02 PM
awdsvx awdsvx is offline
Smile radiator
you can try the other website that other guy stated or go to subaruparts.com
or try:
www.svxparts.com
the site is under construction but if you go there they give you a phone number to call.
1-866-528-5282
Good Luck!
Old 03-20-2003, 07:11 PM
MINEZ BETTER
order parts online is a bad idea. just go to a local subaru dealer and get one. so theres no hassle if it ever happens to have any defects
Old 03-20-2003, 07:21 PM
Kurt_W Kurt_W is offline
^ has Subaru issues
Send a message via AIM to Kurt_W
http://www.newsubaru.com/LIBERT~2/Partsx.html
Liberty Subaru has the best price, $292.22, for the radiator that I could find. I ordered mine last week and it came in 2 days (NJ to OH) and was in great shape (ie no shipping damage). They also base shipping on actual costs, unlike www.subaruparts.com. Freight on the radiator cost $7.85 thought I imagine it might be a bit more if it has to go future.
Old 03-20-2003, 07:25 PM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
Except most dealers refuse to charge less than retail or higher than retail for parts. These online stores offer substantial discounts off of retail and the service is first rate.
I'd never go to a local dealer for parts.
Doug
1994 LSi (4/93)
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Old 03-20-2003, 07:38 PM
MINEZ BETTER
well my exsperiences with the subaru parts is they suck, i ordered two new headlight assebly from them. after a few month of using it, i found out that internally it was defective. i called them and they said we would have to inspect them. well i said f@@k you. since soa had a warrenty for every product it sell in parts counters. i tried one dealer here in walnut creek and i said heres my paper work i need a new one, they wanted to charge for a new head light plus inspection time so i said f@@K you. so then i went into downtown subaru in oakland. they ordered one and switched one for me. that was service. welll the point is online is a hassle when you need to exchange parts because they will just throw you around
Old 03-20-2003, 09:16 PM
elninoalex's Avatar
elninoalex elninoalex is offline
Registered Abuser
How bad is it cracked?
Mine was cracked at both the top mounts about 2 or 3" on each side. I was able to epoxy it and it has been fine now for about 8 months. Cost about $6.
92 Ebony - Level 10/n2o REAR-ENDED
92 Teal - painted yellow/4.11 5spd/n2o SOLD
92 Claret - 4.44 SOLD
94 Barcelona - FWD SOLD
92 Ebony - 3.90 SOLD
94 Laguna ROLLING w/4.44s/Ecutune ECU +TCU/STI springs/Infiniti M45 rims
Old 03-21-2003, 12:34 PM
calmone
thanks for the replies and info. the crack is not small, on the top, fair amount of leakage. i called liberty subaru and ordered the part. hope as the result to make it to redding in the subbie:>
