Old 03-17-2003, 09:40 AM
Aredubjay's Avatar
Rat Fink Member ~:o)
Originally posted by Mr. Pockets
You've got nearly a month before the meet, the part is less than $50, and you knew your engine was bad a month ago.
When your car stops moving one week before the meet, then we'll talk about 'meet monsters,' okay, champ?
Heck, if you recall, I pulled mine out of the shop and drove straight to Vermont. Then, I pulled it out of the shop and drove it to Reading II.
Don't count it out 'til it ain't on the road, headed toward Reading the day of the meet.
Let's just hope the flexplate fits when it gets there.
BTW, I thought 1stsubaruparts had folded. OR, are they just not stocking SVX parts any more?
Randy Johnson
Mike Davis -- at Reading VI
Old 03-17-2003, 04:08 PM
SVXPILOT SVXPILOT is offline
flex plate
Mine is on its third possibly 4th that I'm aware of. Many will remember the car at the tenth anniversary meet that was making a load noise under the hood. I made an appointement for 3 days later in golden CO. to have it fixed and it was broke all the way around the center bolts in an octagon shape so it was still able to drive the car. I suspect it was like that when I left ME to go to the meet.The one before that let go from the outer bolts in towards the center. Only 20 thousand miles between 3rd and 4th flex plate. It sounds as if it might be going again. I drive with to heavy foot. Time for 5sp ,6sp, or weld two flex plates together.
Old 03-17-2003, 06:24 PM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
They are still in business. I recall something about them losing their Subaru dealership and having to partner with another, but they are still in business and still the cheapest i have found so far beating subaruparts.com by several percent on each item and lower shipping charges.
Doug
1994 LSi (4/93)
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Old 03-18-2003, 04:58 AM
svx_commuter's Avatar
Re: flex plate
I think there is something wrong with your engine to transmission alignment.
The flexplate is the coupling between the engine and the transmission shafts for axial alignment only. When the engine and transmission line up correctly and the crank shaft and TC are on center there should be only torque loads going thru the plate and these will be very low. When the shafts do not line up in the laterial direction very high bending loads will result in the flexplate. Then it will break from fatigue failure.
Old 03-18-2003, 01:05 PM
You can tell from the part number which Subaru it belongs to.
00000AA000 - Legacy/Impreza (multiple/unspecific?)
00000PA000 - SVX specific
00000FA000 - Forrester specific
00000GA000 - ??
Old 03-18-2003, 04:08 PM
That was the cuase of plate #3 so said the dealer in Laffayette ID. I visited them after the meet before leaving town and would have had them fix it but they wouldn't get to it for 3 days. so I booked an apointment for three days later in Colorado. They noticed tha one of the dowels was missing and replaced it. I'll drive it till I know it's the plate again and the dealer hear will fix it under warranty.
