Old 02-25-2003, 06:29 PM
92SvxChick
If you had bad O2 sensors...you would get a check engine code.
Megan
Old 02-26-2003, 07:19 AM
Originally posted by CigarJohnny
My low fuel light sensor is the only thing that seems to work properly. Unless the tank is full the fuel gauge won't go above empty. Then when it does it stays above 3/4 for a bit then plumets down to empty after a few gallons are used. Very crappy situation if that is a common problem with the SVX. I just thought it was mine. I never heard of a car with such a cheesy gauge let alone such an expensive flagship model
Mine has got worse and gone that way too. I still trust the low light.
There is a how-to post on here that shows how it can be reset, needs a battery disconnect and a memory dump to achieve it.
Do a search, I think it looked simple and effective, just never got around to resetting mine.
