Old 02-23-2003, 02:42 PM
Subafreak's Avatar
Superbeast
Windshield rubber?
I was just out running my SVX and noticed the rubber trim that runs around the windshield is all wrinkly up the sides right where it suppost to lay flat on the glass, and it wasn't like this a week ago? Anyone else have this problem? Is it easy to get a new one installed or does it get glued in with the windshield?
What do I do it looks like crap.
Old 02-23-2003, 08:31 PM
SVXdriver_007
paint it orange or take it from the dumba$$ who has one parked at your garage. He'll never notice.
Old 02-24-2003, 01:13 PM
cbx-man cbx-man is offline
Re: Windshield rubber?
That will happen in freezing weather. The root of the problem is junk working it's way under the rubber and expanding when it freezes. I live near fir trees that dump needles on my car that insidiously work their way under there.
One thing that I've tried is to get very thin plastic, like the immitation "credit card" material in junk mail, and cut a "J" hook into it and the push it in between there and dig out the crap. The card will go down in an inch or more, but it slides in easily. It does help with the wrinkling.
cbx-man
'92 LSL Liquid Silver / Automatic Level-10 valve body mod / remote filter
'92 LSL Pearl White / 5 spd. IndigoSpeed 11# flywheel / ACPT Carbon fiber drive shaft
'80 Honda CBX in-line 24 valve 6 cylinder
Old 02-24-2003, 05:41 PM
Subafreak's Avatar
Superbeast
Thats all good but what do you do when it's already F'd up.
I could practice changing it on Proj.007
Found the piece on Suby parts It like $27. and called the Damn rubber thing, or somthing like that. I just want to know if anyone has changed this before?
Old 02-24-2003, 06:45 PM
svxtremist2001
Laughing my ****ing ass off the damn rubber thing! That is good secret man. Seriously tho you can change that out with a mid range heat gun the old part should lift off without having to move the windsheild just be careful not to move the windsheild so it stays centered. Then the next rubber frame should come with peel off and adhezive on it to stick over and then let it dry a while before you drive it ok?
