Old 12-28-2002, 10:13 AM
BLKSVX92's Avatar
BLKSVX92 BLKSVX92 is offline
Casper Killer
Send a message via AIM to BLKSVX92 Send a message via Yahoo to BLKSVX92
http://www.subaru-svx.net/photos/fil...SVX92/3972.JPG
Michael
1992 SVX Build 4/91 SOLD TO gsodonis
2002 Civic Si SOLD
2005 Lancer Evolution VIII TRADED
2008 STi
Old 12-28-2002, 04:03 PM
DavieGravy DavieGravy is offline
Here you go SVXENO.
Actually, it's not as clean as it could be, but I wanted to get all the ATF that I sprayed everyhwere out. Plus, I wanted to clean off the hoses around the external tranny filter to notice if there's a leak. A wasn't sure how tight the clamps should be.
BTW laundry detergent and a scrubbinbg brush cleans rims far better than Meguiars gold and glass. They're not perfect, I know, but at least I they're clean.
Old 12-28-2002, 06:11 PM
svxeno
Davie - Betchya thought I wouldn't check back.
Looks alot better than mine. It was fairly clean until the grounds keeping crew around my office managed to blow a bunch of leaves and cuttings into my engine compartment.
I've thought about spraying it like you did but am fearful of the same thing that happened to you. I have to get it (and the Fiat) cleaned up somehow.
Randy (If I clean it I'll break something good and expensive) ii
Old 12-28-2002, 06:46 PM
seasvx's Avatar
seasvx seasvx is offline
BLKSVX92, do you know who's car this is?
Old 12-28-2002, 07:35 PM
BLKSVX92's Avatar
Casper Killer
sorry....i dont
Michael
2002 Civic Si SOLD
2008 STi
Old 12-28-2002, 07:41 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Here's how I do a quickie clean-up on customers' cars at the shop:
Spray the nasty part(s) with brake clean (I prefer Brake clean over carb clean because it's usually not flammable - check the can - it will surprise you if a plug wire or coil lights it up - personal experience )
Start the car and let it warm up about half-way, this will help soften the yucky stuff and also provide some heat to help hasten the drying process afterwards. Shut the engine off and spray liberally with Simple Green - 50%/50%, SG/water - Let sit about 5-10 minutes then blast it with a hose.
Try to not force water into anything, particularly electrical components and stuff like air filters, etc. If you're working with a car that has a distributor you can 'bag it' with a sandwich bag or similar and tape or rubber bands before beginning.
At the shop I use an air hose to give it a quick blow-off, at home I use the outlet blast from the shop vac. If you don't have one use a hair dryer, it'll work, just slower. Leaf blowers are good too, but the neighbors will probably give you funny looks. Pay particular attention to the electrical goodies, blowing the water away from them, not into them. Start the engine and if it runs rough for more than a minute or so shut it off and go back to the drying device you have handy. That's all there is to it!
p.s. I recommend doing this at home rather than a car wash, at least until you've got the hang of it. There's nothing like the added frustration of being stranded at the car wash, by your own doing, with people waiting behind you to use the bay. I don't even like doing it there unless I know the car well.
Old 12-29-2002, 04:09 PM
$VX
I don't like em chrome. No offense. Just my opinion, but the remind me of those 20 dollar k-mart hubcaps.
- Ca$h
PS: There's lots of stuff under the hood that isn't meant to get hit with water at the pressures of a pressure washer. If ANYTHING, use simple green and a HOSE. Not a pressure washer, and cover up your electronics with a bag or something. I prefer just doing it by hand. :|
Old 12-29-2002, 06:03 PM
None taken, but I don't think they resemble Kmart hubs. Maybe if you saw them in person... That shot was a bad angle.
