Old 10-19-2002, 09:27 PM
Invisible avatar
Question Oh, no! The dreaded 105K check-up!
A couple weeks ago I received one of those nice multi-colored form letters from the Suby dealership that last worked on the car that began - "Dear Mr. M: "To protect the value of your Subaru & keep it at top performance, yada-yada - our records show that your mileage should be approx. 104,583 & may now require the following factory maintenance": 105,000 Mile Maintenance. Call us for app't. etc, etc.
Now this is the dealer that I bestowed about $1,800 upon in June to perform essentially a pre-mature 120K check up (timing & A/C belts, plugs, fluids, water pump, cam seals, wheel bearing etc. & all has been fine since. But I'm sure the computer is programmed to let me know that I missed something & please come back so we can collect some more sheckels. So, I just wondered if anyone else has this 105K "milestone" service check up & just what is it they'd like to sniff out?
Thanks, Ron.
'96 Grand Caravan - 240K
'01 Miata SE - 79K
Old 10-19-2002, 09:31 PM
Green1995SVX
Replace Engine oil
Replace Engine oil filter
Inspect Disc brake pads and discs, front and rear axle boots and axle shaft joint portions
Perform Inspect brake lines and check operation of parking and service brake system
Inspect Steering and suspension
That's what http://my.subaru.com says for the 105k service.
Mike
Old 10-19-2002, 09:39 PM
Invisible avatar
Talking
Originally posted by Green1995SVX
Replace Engine oil
Mike
Ah-ha! One of those Sherlock Holmes inspection tours. Thanks Mike, I shall go inspect all of those suspicious items myself & if any metal parts have separated themselves from the car, I'll be sure to tow it in on Monday.
Ron.
'01 Miata SE - 79K
