Old 09-28-2002, 03:00 PM
DNSB
Rotors
I have to fix my rotors soon, and I wanted to know, if the years 92-97 SVX use the same exact rotor?
And can I put a rotor on my 92 SVX, that is parted from a 91 Legacy?
~Deja~
Old 09-28-2002, 03:07 PM
nubs's Avatar
nubs nubs is offline
Multiple Suby Owner
Legacy rotors will not fit. The bolt patern is diffferent . Without checking, the size is probably not the same either.
Old 09-28-2002, 03:59 PM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
Re: Rotors
~Deja~
Also, the front and the rear rotors are different (in size) so the dealer says.
Lwin
Lwin M. Maung (Member # 147)
Current SVX: NONE
Old 09-28-2002, 04:53 PM
I doubt you would have a match for the SVX rotors in your yard of Subies. One person mentioned they were a Nissan part.
Couple options:
1. new OEM rotors
2. Race Concepts rotors (no one has mentioned them in a while)
3. ART http://www.appliedrotortechnology.com/
I'm sure others can add to this list.
Old 09-28-2002, 09:35 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
I had a few extra minutes today so I tossed on the ones I bought through Ebay. Four drilled, slotted, balanced and cad plated for $249. (I just had mine slotted, I didn't want them drilled) They work just fine, I'm just waiting for the slot edges to smooth out a bit, they're a little noisy at first.
Old 09-29-2002, 08:04 AM
immortal_suby's Avatar
Thread Killah
Beav - I just bid on a set of those yesterday. Mine are starting to crack and I guess its time to replace. Did you win the auction on e-bay and then call them or just skip ebay and call them to get them not to drill them out. They are still listed as being brembo brakes. Hopefully they actually are.
Did you check the trueness on these before you put them on?
Locker Link
2015 BRZ Limited 6MT
Old 09-29-2002, 01:02 PM
Beav's Avatar
Not as old as Randy
Yeah, I won the auction but I tend to believe it really doesn't matter to anyone there. The guy asked "Did you win?" and I replied "Sure." That seemed to be good enough for him.
I would definitely call and have them NOT drilled, surface area does count. And for those that say they have a better pedal, stopping power, etc. all I can say is they must have had some really crappy brakes beforehand. While these stop well enough, they bolster my belief in swept area being the most important attribute.
BTW - don't install expensive pads with these rotors until after they've had a chance to polish the edges a bit. Some rotors are chamfered at the slots and some aren't - these aren't. I would have gone ahead and relieved them at the beginning but that would ruin the nice cad plating job (they do look cool after using them for a day or so.)
I checked the rotors with a dial indicator when installing and the most runout I found was .002 which is more attributable to mounting/flange runout than to the rotors. I didn't mount them on the balancer to check balance but they haven't done anything noticeable to the ride. I think I'd know, I'm kinda picky about that. I've balanced the shafts and hubs at each wheel (like we used to do with driveshafts years ago.) What a PITA that was. I did find out that the o-rings around the cv boots keeps the boots from wadding up at high speeds and causing a shaft vibration. Currently I'm trying to come up with some thermoplastic boots to replace the stock rubber ones - longer life and no vibe troubles...
As to whether or not they're Brembos - who knows? They send the rotors out to be machined, balanced and plated then send them out UPS to their customers. Mine came packed in one box with paper and cardboard separating them. If they're not Brembo they appear to be very similar and seem to be high quality.
