Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Brake Upgrades
Old 03-30-2013, 06:19 AM
'E''s Avatar
'E' 'E' is offline
8 pot brembo calipers
They will fit
92 pearl SVX about to revive
92 Black 4ws (Jap spec) SVX
93 black SVX
93 Liquid Silver SVX - sti 6 speed with R180 diff, my05 sti steering wheel, sti alloy lateral links, 19x8.5 275/30 42mm offset front and 19x8.5 275/30 22mm offset on the rear, 6 pot brembo caliper with 355 rotors front, 2 pot brembos rear
95 bright red SVX
96 emerald pearl SVX about to revive
Old 03-30-2013, 06:21 AM
'E''s Avatar
'E' 'E' is offline
Re: 8 pot brembo calipers
And one more pic
93 black SVX
95 bright red SVX
Old 03-30-2013, 06:46 AM
Tireiron Tireiron is offline
Oh now you tease.
Old 03-30-2013, 07:16 AM
'E''s Avatar
'E' 'E' is offline
Aren't they sexy
93 black SVX
95 bright red SVX
Old 03-30-2013, 07:02 PM
theflystyle's Avatar
any more details then "they will fit"
they look so nice
1994 SVX LSi
2008 Legacy 3.0R
Old 03-30-2013, 08:20 PM
'E''s Avatar
'E' 'E' is offline
They are an addition to the 6 pot brembo kit Ive made using a minimum 34x355 rotor and using the same (slightly modified) mounting block as the 6 pot kit, they will offer even more clamping force then the 6 pot though.
These are the same 8 pots seen on lambo's and Audi r8's etc and should be cheaper to put together then the 6 pots if you buy second hand calipers with my mounting blocks
93 black SVX
95 bright red SVX
Old 03-30-2013, 08:21 PM
'E''s Avatar
'E' 'E' is offline
And like the 6 pot kit will fit all other subies
93 black SVX
95 bright red SVX
Old 03-30-2013, 11:03 PM
EdWindows's Avatar
EdWindows EdWindows is offline
5spd + coilovers = win :D
Looks like they'll stop hard enough to smash my face into the steering wheel.
Also, I assume it costs ~$5000 USD?
1992 Dark Teal LS-L w/ 165k+ miles (traded )
Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs
2001 Black Toyota Sequoia (hauler/daily)
1992 Blue Toyota Cressida (drift car)
1992 Red Toyota MR2 (weekend/track day car)
Old 03-31-2013, 12:17 AM
'E''s Avatar
'E' 'E' is offline
I bought those 8 pots for AU$1,500 so add mounts and rotors might end up costing AU$2,500-$3,000
93 black SVX
95 bright red SVX
