Old 03-12-2013, 10:42 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Rattling under the car
Something is loose and rattles under the car while driving over rough roads. I narrowed it down to the brakes, but I can't find anything wrong with them. The calipers are tight and the brake pads are fine. Is there anything else I should check?
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 03-14-2013, 06:19 PM
dannmarr's Avatar
I work for my SVX
Re: Rattling under the car
Did you check the brake pad shims?
Subaru SVX for fun
Old 03-15-2013, 05:34 AM
dcarrb dcarrb is offline
How did you narrow it down to the brakes? A driveline/exhaust heat shield gets my vote.
dcb
Old 03-15-2013, 12:53 PM
dannmarr's Avatar
I work for my SVX
The sound goes away with the brakes slightly being applied. Thanks for your response!
Subaru SVX for fun
Old 03-15-2013, 01:05 PM
Sounds like the caliper guides are worn on the front brakes. 2 out of 3 of my SVXs showed the same symptoms. I replaced the front calipers with rebuilt ones and the sound went away. You'll want to order a set that includes the brackets.
Is it a rattling sound especially over washboard or rapid small bumps in general?
If so, that's the ticket.
Old 03-15-2013, 01:28 PM
dannmarr's Avatar
I work for my SVX
Over washboard and slightly imperfect roads. It's not a laud sound but annoying.
Subaru SVX for fun
Old 03-17-2013, 03:07 PM
dannmarr's Avatar
I work for my SVX
Found the problem! One of the brake pads detached from the backing plate. It stayed together because of 2 indents, but it wasn't bonded together anymore.
Subaru SVX for fun
Old 03-17-2013, 03:21 PM
Good to hear. Or actually not to hear.
Old 04-13-2013, 07:39 PM
dannmarr's Avatar
I work for my SVX
The rattling came back. While installing new brakes and rotors, I noticed my front caliper boots were torn and one was barely moving while appying the brakes. I hope this is the problem I was hearing. I'm picking up a repair kit tomorrow.
Subaru SVX for fun
Old 04-14-2013, 04:41 PM
dannmarr's Avatar
I work for my SVX
Forget about the rebuild kit. My calipers are toast, front and rear. Seized pistons, seized pins, rusted throughout, torn boots, dirty contaminated fluid.
I replaced the calipers about 2 years ago. This is what happens when the car sits for a long time at the mechanics shop. Anyone have recommendations where to buy? Also, what is the best way to drain out the old brake fluid? Add as you drain?
Subaru SVX for fun
Old 04-14-2013, 08:05 PM
This is the best deal I've seen for fronts: http://www.ebay.com/itm/271054013964...84.m1438.l2649
He has right side also. The rears are very common. These are a good price: http://www.ebay.com/itm/Subaru-Legac...k_Parts_Access
Old 04-15-2013, 03:15 PM
dannmarr's Avatar
I work for my SVX
Rockauto.com had the best deal. My local 'National Auto' matched their prices! It only took 1 day to get and the core charge was only $10 each.
I got all 4 calipers with the brackets for $186!
Subaru SVX for fun
Old 04-15-2013, 05:56 PM
Excellent deal.
Old 04-15-2013, 08:40 PM
dannmarr's Avatar
I work for my SVX
Excellent deal.
Thanks for following this thread!
Subaru SVX for fun
Old 04-21-2013, 10:10 AM
dannmarr's Avatar
I work for my SVX
I primed and painted my new calipers and rotors. The rattling has gone away finally. I guess it was the calipers afterall. Thanks for all the responses.
Subaru SVX for fun
