Old 12-12-2012, 08:44 AM
rlutz rlutz is offline
Transmission indicator lights
My rebuilt transmission is working great mechanically, but the gear position lights on the instrument panel are acting up. Everything works fine in gears 1, 2 and 3. But the "D" never lights up. When I shift to neutral, the "R" light comes on. If I wiggle it for awhile, I can get the "R" light off and the "N" light to come on. In reverse, the "R" light comes on fine. In park, the "P" light comes on only if I pull the shift lever backwards against the stop.
This wouldn't bother me much, except the starter interconnect in "P" and "N" is flakey too. I can't start the car without pulling back slightly on the shift lever in park, and finding the neutral starting spot is almost impossible.
My shop put in a different "used" neutral switch with no change. The transmission wire harness had ben buggered up a little from an earlier shop that didn't understand SVX transmissions, and the new shop (who have worked SVX's before, and had one on the lot when I first took it there, yeah!) fixed the connector, but maybe it's acting up?
Any ideas?
