Old 11-09-2012, 07:42 PM
Alternator Problem and Question
I pulled a SVX out of storage and started to drive it on a daily basis. The alternator went out. Checked it and it was only putting out 11.8 volts.
Went to NAPA and bought a new one. Within two weeks, it failed. Checked it and it was less than 12 volts.
They replaced it with another one. Within two weeks, it failed. Is my car doing this, or is it bad luck with alternators? What could be doing this.
Thanks in advance.
Old 11-09-2012, 07:46 PM
Re: Alternator Problem and Question
It's typical "box store" alternator failures. They are commonly failing out of the box or shortly after for any car. Get one from Maniac and I'm sure you'll be fine. Also, make sure your battery is fully charged before starting it as that puts extra strain on the alternator.
Old 11-09-2012, 11:25 PM
Earl,
I second getting one from Maniac. I already emailed your questions to Christian.
Call Christian tomorrow (Saturday) She is usually there on Saturday mornings and early afternoons. Her number is (972) 557-5768
I'm sure she can give you some insights. She has never failed to answer any alternator question I have asked her.
Have you tried swapping it for a known good alternator from another car in your 'herd"?
MANIAC ELECTRIC MOTORS.
Much Cheaper than OEM, better rebuild quality than most out there and also a better warranty.
Stock 95A alternator ...$149.00 outright, $89.00 with core exchange. 2 year warranty
160A high-output alternator...$248.00 outright, $188.00 with core exchange. 1 year warranty
If you order online and enter 4747 in the coupon code, you get free ground shipping. If ordering by phone, don't forget to mention this code as well.
They will also send you a UPS Call Tag to have your old alternator shipped to them at their expense (no cost to you) to credit back the $60.00 core charge.
This is one of the best aftermarket companies I have ever dealt with. Their customer service and commitment to quality and excellence exceeds even my expectations. Christian is very knowledgeable and can answer just about any question you have. Its nice to know companies like this are still in existence.
Look at their feedback ratings on EBAY and AMAZON They don't get any better than this.
Old 11-10-2012, 05:00 AM
processengr's Avatar
Another thumbs up for Maniac!!! I have had several of their alternators including high output and will say it is the best remanufactured alternator for the SVX that I know of.
Cheers! Gordon
1992 Ebony 251k 444 SOLD
1999 Silver SLK230 134k SOLD
1997 Green Outback 137k SOLD
2013 Honda Accord I4 SOLD
2015 Subaru Crosstrek 30k
2018 Tesla M3 30k
Old 11-10-2012, 10:16 AM
Thanks
I put a new battery in it so that should not be a problem. I will call her and get one of them. I figured it was that common box store problem. Just wanted to do it quickly (not the best way I guess). Her alternators are not that much different in price either.
Old 11-12-2012, 12:29 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Make sure it's not your wiring. Are you taking the readings from the alternator or from the other end at the battery?
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 11-12-2012, 06:42 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Anytime I sell an alternator at work i always test it straight out of the box because I came across such failures.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 11-12-2012, 07:04 PM
Subix's Avatar
Subix Subix is offline
My Other car is a GENIUS Car!
I went through 2 new alternators and had zero symptoms or reason to believe my battery was faulty. Sure enough, I had it tested the third time around because it wouldn't turn over with the 3rd alternator and it was indeed bad. It had to definitely been the battery because afterwards I had no issues with the alternator again once I replaced the battery alongside the new alternator. They said the battery started sparking half way through charge so it makes sense it was frying perfectly good alternators within such a short period of time. Don't take their word for it either, I've had one place tell me my battery is good only to take it down the street for a second opinion and tell me it's bad.
1994 subaru svx le 112k
