Old 10-08-2012, 10:58 PM
wolfboy wolfboy is offline
???electrical dash problems???
I was just driving home and when I was getting off the free way all of my dash lights lit up (like when you first fire up the car but then they turn off). I haven't noticed any real performance drops, although I only drove a few more blocks. I turned the car on and off a couple times but it's still there. The car did have a check engine light on for both TPS sensor and knock sensors prior to this happening. Any advice/wisdom on this would be much appreciated...
Old 10-08-2012, 11:20 PM
Wikedjuggalo's Avatar
Rebuilding
Re: ???electrical dash problems???
Thats related to the alternator I believe. If you have the "Christmas" lights going on (all the lights on).
Old 10-08-2012, 11:21 PM
Its the alternator, that is having the problem. Just get it checked.
In Subaru's wisdom they wired all those lights together to come on if the alt has a problem.
Its Just to scare the crap out of you so you take it in and get it fixed.
Old 10-09-2012, 12:19 AM
And if it IS indeed the alternator, you will find that these are the best replacements out there.
CHECK THIS POST
Old 10-09-2012, 05:33 AM
dcarrb dcarrb is offline
In my experience that means, REPLACE ALTERNATOR NOW, but be sure it's not a loose belt or failing crank pulley.
dcb
