Old 09-27-2012, 07:14 PM
teamilluminata teamilluminata is offline
OBD2 engine with OBD1 ECU
Can this be done? Is the engine just the same with different and more sensors? The reason I'm asking is I blew my OBD1 engine in my race car and want to replace it with the lowest mileage example I can find. As OBD2 are newer that may be an option. Emmisions, smog etc are not a concern. It just has to run, well.
Old 09-27-2012, 07:17 PM
Re: OBD2 engine with OBD1 ECU
If you swap the intake manifold, and upper engine harness from the OBD 1 engine, then it will work perfectly. There are less differences than you would expect.
Old 09-28-2012, 06:38 AM
Oh, that's good news. Thanks.
