Old 04-21-2015, 11:28 AM
theflystyle's Avatar
Re: Promblem with coolant system!
Originally Posted by EdWindows View Post
Ummmmmmmm why is everyone buying OE hoses when you can just buy a foot of Gates coolant hoses at your local auto parts store for cheaper??
^ Everyone has different reasons
1994 SVX LSi
2008 Legacy 3.0R
Old 04-21-2015, 02:02 PM
Stevebsy's Avatar
Stevebsy Stevebsy is offline
Administrator
That is the coolant line that goes to the throttle body.
https://instagram.com/p/1v_uKECrQM/
https://instagram.com/p/1v_qeOirQF/
Originally Posted by theflystyle View Post
After much searching for what I was looking for I came across this thread which was the closest topic. I am trying to find the part # for this cooland hose underneath the intake manifold (passenger side). See the picture for what I am asking for. It has the ?'s in the arrow. I also added the part # 807611111 (the little elbow) in case it helps for anyone in the future.
'20 Honda Ridgeline
http://www.x35design.com
Old 04-21-2015, 02:42 PM
Facepalm. It make much more sense after someone points it out lol.
Thanks!
1994 SVX LSi
2008 Legacy 3.0R
Old 04-21-2015, 06:12 PM
Because SOME things are best bought from Subaru!
The slight bend in the #807611111 could be replicated, but LOTS of other Subaru tubing, ( PCV/TB vac especialy) like the oil presure sensor, WATER TEMPERATURE SENSOR(!) should all come obnly from Subaru!
Old 04-22-2015, 12:36 PM
EdWindows's Avatar
EdWindows EdWindows is offline
5spd + coilovers = win :D
Yes, but most hoses can be obtained easier and cheaper than dealer.
I do agree that the crazy bend hoses and sensitive electronics should be bought from dealer, but for a slightly kinked 4" coolant hose on the D/S of the motor, it's more reasonable to pay $2 for a foot of hose and cutting it to fit.
It's like when the die-hard BMW enthusiasts tell me to go OEM for everything because they "manufacture everything to a higher standard" and "BMW engineers know best." If that were the case, there wouldn't be an aftermarket for water pumps with metal impellers because the plastic ones wouldn't need replacing every 50k miles.
/rant
1992 Dark Teal LS-L w/ 165k+ miles (traded )
Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs
2001 Black Toyota Sequoia (hauler/daily)
1992 Blue Toyota Cressida (drift car)
1992 Red Toyota MR2 (weekend/track day car)
Old 04-22-2015, 03:51 PM
Ed, Thank you for your quick and consice responce!
That thing that you just saw was a figment of your imagination
Last edited by svxfiles; 04-22-2015 at 03:58 PM. Reason: Covering my "donkey!" ; )
