Old 11-30-2011, 07:37 AM
jman050's Avatar
jman050 jman050 is offline
Its a Classic!
strange electrical issue
Ok well long story short. 8 months ago I installed a maniac alternator and around a week ago the voltage regulator in it went and it began charging my car at 16-17v. I installed a new alternator. everything works minus the headlights (the fogs,highbeams, and driving lights work fine). In addition my security button continuously flashes and I attempted to turn it off while I was driving and it set off the alarm. The alarm would not go off until I pulled over and pulled a battery cable.
Can anyone tell me what components/ grounds/relays are related???
Anyway I will be in the driveway with my multimeter....any help would be appreciated!!!
[SIGPIC][/SIGPIC]
Old 12-05-2011, 03:20 PM
Re: strange electrical issue
u figure this out?
Old 12-07-2011, 12:35 AM
kwren's Avatar
kwren kwren is offline
one of my SVX's, the 200K one, does this every time I disconnect the battery cable and reconnect it without going in and pushing the security button immediately. It won't "stop the noise" until I disconnect the battery again and push the button again.
Make sure the fuses are ok? Not just a visual check...
Good luck
Keith
Old 12-07-2011, 11:27 AM
jcimos's Avatar
jcimos jcimos is offline
Well have you tried replace the security module? You may have damage it when your alternator went out.
ALL WAYS JUDO CHOPIN'
"Wait...your grill...is that chicken wire?"
