Old 11-09-2011, 04:45 PM
Gamesy's Avatar
Gamesy Gamesy is offline
rad fans stay on
i've noticed lately that my rad fans dont turn off at all now, what would cause this
Old 11-09-2011, 04:48 PM
Re: rad fans stay on
Your fan sensor . I believe it is near the bottom of the radiator . You don't have the climate control on or the defroster right
Green1995SVX's Avatar
Coolant temp sensor is a possibility.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 11-09-2011, 05:05 PM
i second that. after moving around stuff in the engine bay my fans were staying on and it turned out to be the coolant sensor connector had come off.
Old 11-09-2011, 05:07 PM
Gamesy's Avatar
if thats the case couldnt the engine temp gauge on the dash not work either? mine still shows hot and cold
Old 11-09-2011, 05:14 PM
it has two sensors, one for the gauge and one for the computer
Old 11-09-2011, 05:15 PM
No, there is one for the ECU which controls the fans and the air/fuel mixture, etc. and there is one for the gauge cluster.
Old 11-10-2011, 04:40 AM
michael's Avatar
michael michael is offline
What Potholes ???
Is your speedo functioning normally?
Wanted: Steering Wheel
Old 11-10-2011, 08:46 PM
Fan sensor? Really?
2009 Volvo C70 T5
2008 Volvo S80 V8
2001 Audi S8
Old 11-11-2011, 06:40 AM
My old 83 had one at the bottom of the radiator .
Old 11-11-2011, 01:28 PM
SVX92-97's Avatar
SVX92-97 SVX92-97 is offline
CONN 83 WHAT? In my case its always been the coolant temp sensor. Happened in my legacys and my prior svxs
1995 POLO LSI 76K MILES SOLD
Old 11-11-2011, 03:02 PM
It was an 83 GL wagon. You call it a sensor or a what ever It is in the coolant and when it gets hot it turns the fan on . So chastise me for calling a FAN sensor .I stand corrected it is a coolant temp. sensor
Old 11-11-2011, 05:24 PM
It actually does quite a bit more than turn on the fan. It's also not in the radiator, but rather in the top of the engine block. Subaru did change one or two things between the 1983 GL wagon and the SVX.
2009 Volvo C70 T5
2008 Volvo S80 V8
2001 Audi S8
Old 11-15-2011, 08:14 AM
Maxo's Avatar
Maxo Maxo is offline
Would a bad temp sensor cause the fans to just come on more often? My fans aren't staying on but seem to be turning on and off more than usual, especially considering the high temps have only been in the 40's.
They both come on right away when the car is started and I've watched as they would turn on then off for a few moments then back on again.
I replaced the temp sensor probably 2 yrs ago. Seems kinda early for it to go bad again.
Old 11-15-2011, 10:58 AM
Did you replace with OEM, and you replaced the 2 wire sensor, correct?
