Old 11-02-2011, 07:08 AM
Elaine Elaine is offline
4.44 4EAT swap questions
I have a couple of questions I couldn't find a clear answer for in all the previous threads (I'm trying to install a '97 Outback 4.44 EAT on a '92 car):
- Do I still need to use an external ATF oil filter?
- Do I need a different oil cooler or the stock one is still good enough?
Thanks in Advance,
El
92 Pearl White LS-L 215,000 KM
smallcar 5MT, Ecutune 1.5, SS brake lines, svxfiles 6000K HIDs, $15/15 min mod, $20/20 min mod, Front and Rear Energy Swaybar Bushings, Bosch Relay Mod
92 Liquid Silver LS-L 127,000 KM
Old 11-02-2011, 08:37 AM
Re: 4.44 4EAT swap questions
1)- Do I still need to use an external ATF oil filter?
2)- Do I need a different oil cooler or the stock one is still good enough?
Thanks in Advance,
El
1)No. LAN and I believe they restrict oil flow.
2)A different one,
(any one from Hayden/Imperial for example)
will be much less restrictive to oil flow.
BTW, when you are done with stock tires your speedometer will read about 5.5% too high.
Old 11-02-2011, 08:49 AM
2)A different one,
Is it any optimum size for the Hayden/Imperial oil cooler? I remember reading that cooling the ATF oil too much is not really helping...
Old 11-02-2011, 10:21 AM
Huskymaniac's Avatar
Uses the ignore feature
That is true. Really, not much actually cooling is required. You are towing zero pounds. The stock cooler has a pretty low cooling capacity. I calculated it once but i don't recall what I estimated it to be. I do recall that it would have been rated at about the gross vehicle weight. If you go with a low rated cooler, you might want to lean toward a tube and fin versus a plate style. For smaller coolers, the tube and fin are less restrictive to flow.
Tony
