Old 10-31-2011, 02:28 PM
THE NEW GUY THE NEW GUY is offline
any manual with pictures on how to remove fuel injectors?
I need to learn how to remove the fuel injectors but need more info with pictures... any good link?
I have to clean the injectors because I have a code 14. The car runs well but this code was stored in the ecu mem and does not disappear after mem clear procedure.
Old 10-31-2011, 05:05 PM
Re: any manual with pictures on how to remove fuel injectors?
the injectors are pretty straight forward to remove. just have to remove the securing bolts and pop em out. if they are stubborn apply some lubricant and wiggle them a litttle. also disable the fuel pump and crank it over to relieve fuel pressure before removing them or you may get a face full of gas. i don't have pics but if you look on nasioc or nissan forums you can probably find some because the injectors are pretty much the same.
Old 11-01-2011, 07:40 AM
good and thanks
