Old 10-09-2011, 01:32 AM
Gamesy's Avatar
Gamesy Gamesy is offline
fuel line repair options?
when thinking that i only needed a new rubber fuel line between the 2 metal fuel lines turns out the metal fuel line was cracked so i cut it and plugged both ends
should i replace the entire fuel line(body side) or just run a longer rubber hose to connect the 2?
btw does anyone have the fuel line diagram and part numbers? its not in the basic online manal(that i can see)
Old 10-09-2011, 08:03 PM
Green1995SVX's Avatar
Re: fuel line repair options?
When mine went bad, I cut off the bad section of metal line, then ran the rubber line further and clamped it to the good section.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 10-09-2011, 08:07 PM
Be sure to use the good rubber gas line (made for gas ) not the cheap rubber tubing
Old 10-09-2011, 08:23 PM
When you go to the parts store, specifically request fuel injection hose. Then you'll get the right stuff.
2009 Volvo C70 T5
2008 Volvo S80 V8
2001 Audi S8
Old 10-09-2011, 09:21 PM
Cam Cam is offline
+1
2345678
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
