Old 10-06-2011, 08:29 PM
Gamesy's Avatar
Gamesy Gamesy is offline
fuel line hose size
does anyone know what size the hoses are for the fuel lines in between the tank and the metal lines under the rear seat?
one ruptured today and need to replace it
Old 10-06-2011, 08:38 PM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
Re: fuel line hose size
if it's the ones that go above the fuel tank, make SURE you replace all 3 of them. one of mine ruptured and the other 2 were about to as well. they're only $60 each so it's not too horrible. i can't remember the size though.
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 10-06-2011, 08:48 PM
Gamesy's Avatar
$60 each!?!! wtf i'm sure buying it bulk would be cheaper
Old 10-06-2011, 09:00 PM
Cam Cam is offline
5/16th if it's the one that went on mine a couple months back. Under the car, left hand side of the tank
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 10-06-2011, 10:42 PM
B 4 You's Avatar
#lolsvx
but just think, you won't have to replace this part for say, another 20 years. :]
if we're talking about the same lines, find a cheap (price, not quality) mechanic... it's like a 6 hour job. the whole rear end needs to come off to get the gas tank off to reach the end of the lines, it's pretty serious.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 10-07-2011, 05:01 AM
Gamesy's Avatar
ya i noticed that those lines will have to be replaced later on
Old 10-07-2011, 09:38 PM
Gamesy's Avatar
good news: it is 5/16"
bad news, wasnt the hose, the metal fuel line cracked on the seat side, not the tank side
