Old 09-20-2011, 06:44 AM
92NJSVX 92NJSVX is offline
Headlight issue
I just changed the left side headlight bulb in my 91 and now the light comes on dim and so does the high beam bulb. When I turn on the high beams both lights cut out.
Anyone else have this issue?
Adam
Old 09-20-2011, 10:19 AM
Re: Headlight issue
Check your connections to the bulb. Might have to use dielectric grease.
Old 09-20-2011, 05:24 PM
Re: Headlight issue
Adam
Check the ground wire near the light.
Old 09-22-2011, 06:40 PM
Re: Headlight issue
Thanks, Ill check both.
Cheers,
Adam
