Old 08-18-2011, 06:32 PM
steveherman steveherman is offline
Windshield Wipers
can someone post pictures of the front wiper arm placement with the winter mode on and with the winter mode off?
please and thanks
steve
Old 08-18-2011, 06:57 PM
dbarnblatt's Avatar
Re: Windshield Wipers
Here you go:
Old 08-18-2011, 07:15 PM
i see the problem. mine is missing those blocks that rest on the stops at the bottom of window
Old 08-18-2011, 07:38 PM
am i seeing that correctly?
can i buy those blocks or do i need new arms?
Old 08-18-2011, 07:49 PM
You will need the new arms. That is a common mistake that people make - they replace the arms and wipers together instead of just the wipers. Then they don't work right.
Old 08-18-2011, 08:02 PM
are they available?
can someone give me a detailed picture of what both sides look like i would hate to buy a set and not be correct?
Old 08-18-2011, 08:14 PM
You dont need new arms, just the replacement OEM wiper blade assembly (for which you can buy refills)
The aftermarket blades are universal and do not have the attached blocks that the OEM ones do.
Parts 1 & 2 in the diagram
86542PA040 ...Wiper Blade Assembly/ Driver's side ...$20.54
86548PA010 ...Wiper refill/ Drivers side ...$7.24
Parts 3 & 4 in the diagram:
86542PA060 ...Wiper Blade Assembly/ Passenger side ...$19.03
SOA591U320R Wiper Refill/ Passenger side ...$4.53
Old 08-18-2011, 08:26 PM
sweeeet
are they usually in stock or special order?
thanks
Old 08-26-2011, 07:36 AM
THE NEW GUY THE NEW GUY is offline
my friend SVXCESS, can you please send some pics of the block attached to the blades? Mine doesn't have it neither.... Now I know why it doesn't make any sens to me to have the blades squised on the small ramp.
Old 08-26-2011, 08:35 AM
Originally Posted by THE NEW GUY View Post
my friend SVXCESS, can you please send some pics of the block attached to the blades? Mine doesn't have it neither. Now I know why it doesn't make any sense to me to have the blades squished on the small ramp.
Its a small square plastic block riveted to the blade assembly, right at the pivot. Have them check the part numbers again. I never had a problem with these numbers.
Packaged wrong? I've seen it happen.
