Old 07-15-2011, 09:06 AM
Tapani Tapani is offline
Refrigerant control valve?
Hi all,
The Zexel DCW17BE a/c compressor is of variable displacement type and the discharge is controlled by a valve within the compressor. Does anyone know if this is an electric one controlled by the computer or a sealed mechanical one? There are two wires that go into the head of the compressor - are they for a speed sensor or the control valve?
My low side pressure is high (45-50PSI) and the high side low (140-150PSI). This is still an R12 unit, but running with R49 juice (just evacuated and refilled).
The symptoms could be caused by either a bad compressor, a sticking control valve or a malfunction in its control....
Is there a way to override the valve i.e. force it to produce maximum discharge.
Any insight to how the whole control system works would be much appreciated.
I also have a code 34 - mode door motor, but the mode selection does seem to work. There is funny sound from the dash, though - like creak every second or so.... like something rotating and rubbing. Any ideas?
Best regards from Finland,
Tapani
1992 claret turbo
