Coolant loss.. ??
I just had enough "coolant loss" to get air bubble .. and overheat.. ? (107 deg in Fresno)
Temp went up .. and AC stopped working.. . Has worked fine one day after refill (was down ~ 1/2 gal+ after "boil over" .. . Oil looks good .. no milk .. ? How often.. and how shud coolant change and/or flush be done.. ??
Jim 1995 Laguna Blue SVX AWD L - 240K (daily driver) - "ReBuILT" used engine at 236K miles (6/13) 2013 Veloster Red - Driver Now??Dropsprings [1/2" rear, 1" front] with Koni Strut Inserts> Magnaflow Exhaust System> ECUTune Stage 1av1 Upgrade (from 1v4)> ECUTune TCU MOD> Aluminum Crankshaft Pulley> Stainless Brake Lines> Phenolic Spacers> Perforated Brake Rotors (dint like, OEM now)> SmallCar Shift Kit (resting since TCU MOD)> 7-Position Ground System> High-Pressure Fuel Pressure Regulator (resting)> ATF Cooler & Campaign Filter> Yellow Polish Polyurethane Bushings> Pioneer Double-DIN Stereo with JL AUDIO Speakers> Driveshaft Rebuilt with C-Clip U-Joints> 15 Min MOD> 20 Min MOD .. . (2011) Valentine One Radar Detector with Remote Display - ucan'tseeme! |
Re: Coolant loss.. ??
The only time I ever had that happen to me was when the radiator cracked.
I would also make sure both... the two fans, are coming on correctly. Good luck. Keith Last edited by kwren; 06-26-2011 at 09:51 AM. |
and... look for small drips under the car... especially where the water pump is located.
Keith |
I just flushed coolant system.. seems to run fine (?)..
It was along time .. 6 mos to a year since I checked .. OOPS! Good ideas guys! Dont know where water pump is tho? .. Ha! Radiator replaced 3 to 5 years ago.. so shudn't be cracked, BUT .. ?? It was 107 degrees that day here! Thanks..
James,
I don't see an answer to Keith's inquiry regarding both fans coming on and working correctly? This was the cause of an insistent overheat condition last summer on my '97, and was found to be caused by a blown fuse for the A/C controlled fan. The car ran HOT, and the A/C was intermittently blowing hot then cold, with ambient temp over 106. Actually, I have yet to solve the problem, but avoid it by refraining from leaving the climate control on Cool, causing the fan fuse to blow when ignition is turned "On". I've duplicated this "condition", repeatedly blowing the fuse deliberately, and suspect it's a problem with one of the A/C relays. If the car is started, then climate control switched to A/C, everything works correctly. Anyways, check your fans. Glenn
"The only thing necessary for the triumph of evil is for good men to do nothing" Aaron Burke 1993 25th Anniversary Edition #63 of 301. R.I.P. Rojo 7/24/2008 She saved my life! 1997 Ebony Mica Pearl LSI. BLACKBERRY 1998 5-Spd Legacy GT Wagon in Glacier White: NUBURU 2005 Cadillac STS in Sandstorm Metallic: STORMY Veteran and farthest traveler of 1st SoCal2MuseumsMeet2010. http://www.subaru-svx.net/photos/user.php?RojoRocket |
Think fans were both on.. . but works fine now.. I topped off, got a new cap (old one probably OK), and then Flushed/Changed coolant Sunday. Not quite as hot now .. but still ~95 thru Monday (yesterday and today, like 78 deg and rain.. Ha!).. .
I'll keep an eye on my fans for sure.. if A/C drops.. or Temp raises! Thanks! P.S. Don't know what position "Cool" is on climate control.. ??? But.. I DO know climate control mechanism is VEEEEERY CoMpLiCaTeD! [I got the manual!] I'm so glad mine works.. . P.P.S. Hello, fellow California DeSeRt RaT! Enjojin' da HEET?
Jim 1995 Laguna Blue SVX AWD L - 240K (daily driver) - "ReBuILT" used engine at 236K miles (6/13) 2013 Veloster Red - Driver Now??Dropsprings [1/2" rear, 1" front] with Koni Strut Inserts> Magnaflow Exhaust System> ECUTune Stage 1av1 Upgrade (from 1v4)> ECUTune TCU MOD> Aluminum Crankshaft Pulley> Stainless Brake Lines> Phenolic Spacers> Perforated Brake Rotors (dint like, OEM now)> SmallCar Shift Kit (resting since TCU MOD)> 7-Position Ground System> High-Pressure Fuel Pressure Regulator (resting)> ATF Cooler & Campaign Filter> Yellow Polish Polyurethane Bushings> Pioneer Double-DIN Stereo with JL AUDIO Speakers> Driveshaft Rebuilt with C-Clip U-Joints> 15 Min MOD> 20 Min MOD .. . (2011) Valentine One Radar Detector with Remote Display - ucan'tseeme! Last edited by James Scott; 06-29-2011 at 07:02 PM. |
