Old 11-29-2010, 09:15 AM
longassname's Avatar
Just some dude.
Sold-12,000 RPM 8.5 compression short block for sale
The short block from my engine build howto thread ( http://www.subaru-svx.net/forum/showthread.php?p=663645 ) is for sale. This engine is built for Turbos and high RPMs.
The high lights are:
Ballanced past 12,000 rpms
Coated ECUtune high silicon aluminum main bearings
Coated ECUtune high silicon aluminum rod bearings
Perfect oil clearances with tolerances 20x more precies than OE
Eagle H-beam rods with arp 2000 rod bolts
8.5 compression forged pistons with thermal barrier top coating and anti scuff sidewall coating, tool steel pins, and stainless rings
.0015" step deck
In short the most awesome short block you could build for forced induction, fully documented, fully proven, and broken in with about 3,000 miles and a 7800 rpm red line. $2,900
Old 11-29-2010, 11:26 AM
Cam Cam is offline
Re: 12,000 RPM 8.5 compression short block for sale
Why are you selling it Mike?
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 11-29-2010, 11:32 AM
Just some dude.
Because I'm going to go high compression naturally aspirated. This shortblock is strictly for forced induction engines.
Old 11-29-2010, 11:35 AM
Cam Cam is offline
I like the way you think, Mike. GLWS
Cam
'92 Ls-L Dark Teal
Old 11-29-2010, 12:51 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Michael,
Just for folks that miss the "short block" aspect of your thread title, what you're selling is only what's shown in the picture, correct?
-Bill
p.s. what cams and HGs did you use during the 3k miles?
Retired NASA Rocket Scientist
Center Network Member #989
Old 11-29-2010, 03:43 PM
Just some dude.
What's in the picture plus the oil pump.
244 intake with 264 exhaust cams. OE head gaskets
Originally Posted by SVXRide View Post
Michael,
-Bill
Old 11-30-2010, 12:59 PM
NeedForSpeed NeedForSpeed is offline
Did you run a charger on this short-block with the cams?
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 11-30-2010, 01:59 PM
Just some dude.
No, the engine this short block was in never got forced induction.
Old 03-06-2011, 08:29 AM
Just some dude.
This has been sold
