Old 04-20-2010, 03:25 PM
jjanak79's Avatar
jjanak79 jjanak79 is offline
Gauge pod
Has anyone put a gauge pod in there svx? i'm thinking about it cause i'm putting a trans temp gauge in it soon so i might as hell put a pod with 2 more gauges.
94 Subaru SVX FWD 51k
04 Mazda B4000 (work truck)
Old 04-20-2010, 04:02 PM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
Re: Gauge pod
I've seen a lot, actually. Even OT has one in his car. It's a double one.
Kinda like this: http://svx-motorsport-accessories.st...pillarpod.html
Old 04-20-2010, 04:19 PM
Old Fogey
Re: Gauge pod
I have one installed by a previous owner, and really don't care for it for a couple of reasons. First, it blocks an already limited sight-line in that area, and mine really doesn't seem to fit correctly. I'm planning to pull it and disable the voltage readout, relocating the trans temp to a more discrete location. Just one opinion.
Glenn
Old 04-20-2010, 08:14 PM
jjanak79's Avatar
Re: Gauge pod
idk. if i get anything it would be a trans temp gauge
Old 04-20-2010, 08:34 PM
Banned
Re: Gauge pod
Id like the pod painted the same color as the interior I will have air fuel trans temp and oil pressure or save it for boost gauge when I turbo I've also thought about a dash one similar to the wrx
Old 04-20-2010, 09:35 PM
jjanak79's Avatar
Re: Gauge pod
i'm looking for a 2 gauge pod that would fit this thing. i'm searching and searching
Old 04-20-2010, 09:42 PM
Gamesy's Avatar
Gamesy Gamesy is offline
Re: Gauge pod
i can customize one for ya if your interested.
Old 04-24-2010, 05:19 PM
Banned
Re: Gauge pod
+1 for pics of your pod
Old 04-27-2010, 03:36 PM
redlinedeath redlinedeath is offline
Send a message via AIM to redlinedeath Send a message via Yahoo to redlinedeath
Re: Gauge pod
what i wanted to do eventually if space permits was remove the stock radio, and seperate cdplayer, replace with a single unit, and use the old cd player spot as a 3 gauge spot, IF they fit. i have no idea if they will... thats been my plan, i figured id get there when i got to it.
Old 04-27-2010, 04:09 PM
Gamesy's Avatar
Re: Gauge pod
unfortunately you cant use the stock cd player without the tapedeck since the wiring harness hooks into the tapedeck. if you get an aftermarket cd player you'll have space for a single din. and i know that there are gauges small enough, my friend has some in his 87 Monte
Old 04-27-2010, 04:37 PM
Schralper's Avatar
Schralper Schralper is offline
Re: Gauge pod
lotsa a heat gun work to get contours right.
used 2 sided tape and permatex to mount
oil psi/ trans temp, hand held mount not included.
WFO!
http://www.cardomain.com/id/Schralper
"You all laugh cuz I'm different
I laught cuz you're all the same."
Old 04-30-2010, 10:44 AM
superru superru is offline
just trying to fix it!
Re: Gauge pod
If i remember it's a 94 mitsu eclipse that uses a pod that fits our SVX.
uhh ya it's a subaru
Old 04-30-2010, 01:43 PM
Gamesy's Avatar
Re: Gauge pod
wouldnt be surprised between that/ 300zx and a 3000gt or ford probe
Old 04-30-2010, 02:09 PM
BoxerFanatic's Avatar
Re: Gauge pod
If you do change-out the stereo for a single DIN stereo unit, Subaru OE from another car, or aftermarket... Something like this (06-07 WRX/STI single disc)...
You could theoretically fit this underneath it. DEFI DIN gauges, a pressure gauge and two temperature gauges. (oil press, oil temp, trans temp, perhaps... depends on what you hook it up to.)
PRODUCT FEATURES
DIN-Gauge is a 1-DIN sized triple meter for providing information on a pressure and 2 kinds of temperatures. "DIN" is an abbreviation for Deutsche Industrie Normen(German industrial standard) and the most of audio hardwares are designed in the DIN size. DIN-Gauge can be neatly installed in a DIN sized vacant space in your automobile.
Three guages are fitted into one DIN size.
The front cover of the gauge has flat face glass.
Opening and closing mode: The needle pointers of three gauges move sequentially.
The three meters are angled towards the driver for a higher level of visibility
Stepping motor: *Maximum angle 270degrees is controlled by the microcomputer up to 4,600 divisions(0.057degrees) to provide high precision in the accuracy of information generated.
*Quick response which is sustainable in racing scenes.
Bright transparent green gauge dials and red instrument needle pointers are used in the gauges to increase visibility at night.
The lights are produced from super high bright LED lamps.
DIN-Gauges for right-hand drives and left-hand drives are available.
This product is for use ONLY on vehicles with a 12V electrical system.
DEFI does good stuff, and I think they possibly even supply some of Subaru's OE gauges, as an OE supplier. Lots of Subarus use these, or larger DEFI separates.
Black dials, green illuminated markings, and orange/red markers, all behind a single panel of clear plastic... pretty much matches the main gauges.
"What you plan, and what actually happens ain't exactly ever been similar..."
1992 Claret SVX. Rescued from certain destruction, and still on the road, where it belongs. Waiting for a bit of a makeover, when I can afford it.
2005 Garnet Red Pearl Legacy GT Limited 5-speed. - The late great Subaru sport touring sedan.
1999 Classic Red Miata, Preferred equipment package 5-speed. Fun, fun, fun, in the Sun, sun, sun.
Old 05-21-2010, 03:13 AM
Banned
Re: Gauge pod
bump from the grave anyone put any in recently???
