Old 07-28-2009, 08:05 AM
SVX_MY_BABY's Avatar
Brake Shim question
I just checked my rear brakes as the inner pad was not making proper contact with the rotor. Cleaned and lubed the slides.
Lots of pad material left but I noticed that the back surface of the inner pad is very corroded. It is so rough I'm sure it can't move when the piston pushes against it.
There is no Shim and I'm wondering if there should be.
If you use a shim do you guys lube between the shim & pad and between the piston & shim?
Thanks in advance.
Old 07-28-2009, 08:08 AM
redlightningsvx's Avatar
Collision Refinishing Tech
Re: Brake Shim question
Subaru shims on the rears fit pretty snug against the brake so I wouldn't lube it.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 07-28-2009, 12:23 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
I usually do both on my brakes, as long as you dont over-do it with the stuff it cant hurt, and it also provides some corrosion protection wherever you apply it. My brakes were piss poor when I bought the car, but after I cleaned the crap out of them and lubed everything up, it brakes like a new car.
