Old 06-28-2009, 10:34 AM
Gamesy's Avatar
Gamesy Gamesy is offline
check engine light
my check engine light goes on and off randomly so at first i thought it might be a loose sensor but could it be from the knock sensor?
Old 06-28-2009, 11:13 AM
the_paynter the_paynter is offline
Re: check engine light
mine does the same thing. It only does it while im on the highway in cruise control. The check engine light will come on... last for about 15mins, then turn off... It drives me nuts but I just ignore it now.
1992 SVX: JDM STI short geared 6-speed swap, COBB short shifter, slotted cross drilled rotors, Smallcar Clear headlight lenses, 1997 Grill.
1992 RHD WRX: EJ20G, 16G, Cusco Coilovers, Wilwood 4pot/2pot brakes, Defi Genome 60mm gauges, Exotic speed downpipe, 3.5" A'PEXi spec GT catback
Old 06-28-2009, 12:21 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Have you checked what code was causing it? If you have a 92-95, its in the HOW-TO section.....
Old 06-28-2009, 12:51 PM
Gamesy's Avatar
i've been meaning to borrow my friends scanner.
