Old 06-08-2009, 11:27 AM
ninefourteener's Avatar
ninefourteener ninefourteener is offline
17x8 w/ 40mm offset
^^^ I know the "recommended" offset is 45-50mm..... correct?
Do you forsee any issues with using a wheel the size listed above?
Tire size recommendations on the stock suspension?
--Matt
1978 Subaru Brat, Gold+rust, project
2006 Subaru WRX, CGM, Cobb stg 3, VF39
2007 Subaru B9Tribeca 7-pass ltd, PSM
1994 Subaru SVX LSi, Bourdeaux
Co-Founder / Site Admin: www.slcsubaru.com
Old 06-08-2009, 11:34 AM
Re: 17x8 w/ 40mm offset
40 mm offset is going to be real close. It will probably wear on the plastic inside the rear wheel wells
Old 06-08-2009, 11:50 AM
Even on the stock suspension????
--Matt
Old 06-08-2009, 11:54 AM
NeedForSpeed NeedForSpeed is offline
It depends on the tire you mount on that wheel
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 06-08-2009, 11:58 AM
I'm "thinking" a moderately sized 225/45/17.
But again... open to suggestions and recommendations.
--Matt
Old 06-08-2009, 12:11 PM
ditto with Nate, that is where you should look. I ran 235/40/18 with 45mm offset, so 225 with 40mm offset with 'moderate' tire is the same spacing, but it will be close. I think Dayle runs 225/40/18 with Murano wheels, I think those wheels are closer to 35mm offset.
