Old 06-07-2009, 08:46 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Re: codes...WOW!!! ATF temp sensor?
23- I think that's the maf
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 06-07-2009, 10:13 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Originally Posted by newkid17 View Post
well i took codes again today and im getting alot less than what i was....
23-Air Flow Meter or Circuit (have no idea???)
31-Throttle Position Sensor or Circuit (which might be why im having these problems?)
33-Vehicle Speed Sensor (VSS) or Circuit (because the gears inside the front diff is broke)
34-EGR Solenoid or Circuit (have no idea???)
ALOT BETTER THAN THE 7 I WAS GETTING B4
It would be VERY helpful for you to download the online service manual for the SVX and refer to the "Tests with codes" section for a step by step guide on fixing your problems. The link to the manual can be found below in my signature.
Old 06-08-2009, 08:56 AM
newkid17's Avatar
newkid17 newkid17 is offline
Send a message via AIM to newkid17 Send a message via Yahoo to newkid17
i counted the power blinks when i started it up this morning and it blinks 16 times if that means anything.??
i also disconnected the battery when i put new plugs in it today, and now my check engine light is not on, i will see if it comes on when i leave, i know it will because of the speed sensor atleast.
Old 06-08-2009, 09:46 AM
That means that there are transmission codes present. You need to go through the process of finding what the actual codes are
Old 06-08-2009, 12:18 PM
NiftySVX NiftySVX is offline
That code is not listed in the manual. It is for the dropping resistor circuit. Check and make sure it is plugged in on the LH fender behind the battery.
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
Old 06-08-2009, 02:55 PM
newkid17's Avatar
is that the plug in mounted behind the battery?
Old 06-08-2009, 03:20 PM
To check transmission codes...
http://www.svx-iw.com/svxiw/article/?category=faq
The "Power" light indicates transmission codes. The following self diagnosis will show any fault codes for the transmission.
To perform the self diagnostic test for EXISTING problems:
Warm up engine by driving at speeds greater than 12mph.
Stop vehicle and turn ignition switch OFF.
Turn ignition switch ON and make sure POWER indicator lamp comes on.
Turn ignition switch OFF.
Move selector lever to D and turn manual switch ON.
Turn ignition switch ON.
Move selector lever to "3" and turn manual switch OFF.
Move selector level to "2" and turn manual switch ON.
Move selector lever to "1" and turn manual switch OFF.
Partially depress accelerator pedal (to turn idle switch off).
Check code as displayed on POWER light. Blinking once every 1/4sec is normal.
To perform the self diagnostic test for PREVIOUS problems:
Move selector lever to "1" and turn manual switch ON.
Move selector lever to "2" and turn manual switch OFF.
Move selector lever to "3" and turn manual switch ON.
Move selector lever to "D" and turn manual switch OFF.
Trouble codes:
11 - Duty solenoid A
12 - Duty solenoid B
13 - Shift solenoid 3
14 - Shift solenoid 2
15 - Shift solenoid 1
21 - ATF temp sensor
22 - Atmospheric sensor
23 - Engine revolution signal
24 - Duty solenoid C
25 - Engine torque control signal
31 - Throttle sensor
32 - Vehicle speed sensor 1
33 - Vehicle speed sensor 2
Old 06-08-2009, 04:21 PM
Yes, it is.
Seth
Past subies:
Other toys:
Old 06-08-2009, 05:35 PM
newkid17's Avatar
i drove it today and the CEL did come back on. im only getting code 31 and 33 now. i dont know why the other 2 dissapeared.
i also realized that when it shifts out of drive into 3rd it will go down to idle, untill i accelerate than it goes. TPS?
Old 06-09-2009, 08:20 PM
newkid17's Avatar
would it going to idle when i leave off the accelerator be something to do with the TPS?
Old 06-11-2009, 08:59 AM
longassname's Avatar
Just some dude.
if engine braking is applied in 2nd gear on decel but not applied or intermittent in 3rd gear on decel then yes the throttle position sensor signal the TCU is receiving is no good.
What is the history of your car? Have your harnesses been tampered with? I suggest you check the ground connection made to the passenger side of the intake manifold next to the throttle body and the ground connection made to the transmission pitching stopper bracket to start with.
Old 06-11-2009, 10:50 AM
newkid17's Avatar
where are all the grounds located at? is there a diagram somewhere?
Old 06-11-2009, 10:55 AM
Just some dude.
as I just said....
on the intake manifold on the passengers side next to the throttle body...
and on the transmission pitching stopper bracket....
Old 06-11-2009, 01:34 PM
I am curious as to this as well. Has someone been inside your transmission? You seem to have a lot of random problems with this car that sound alot like someone has been messing with stuff under the hood.
Old 06-11-2009, 02:18 PM
newkid17's Avatar
i tried my first 4.11 swap with this car.... eversince than i have been having problems, but i am trying to get a little beater car to run around for a while so i can tear everything back out of it and check it out.
i ordered a new TPS yesterday, hopefully it will be here by the begining of next week, and hopefully it will solve that problem. that is the only thing that is wrong with it as of right now. it has not been bucking and carrying on anymore, after i put new plugs into her.
i will check the grounds on it just to be safe. i might of done something when i did the swap.?
