belt changing
i was looking at replacing my AC belt but the pulley's are right up againt the fan shroud, maybe cause the transmission is still out but anyone have have little to no room between the pulley's and the fan? or do i have to take the fan shroud off to replace the belts?
Re: belt changing
I pulled both the A/C and P/S belts without removing anything except the belt cover. I had plenty of room as well. There must be a good 3-4 inches between the belts and the fan shroud and that's plenty of room to get those belts off.
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount (), sporting a "new" tail light bar, silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi |
Re: belt changing
That is all I remove as well. No problem changing them with that removed.
Re: belt changing
hmm maybe its cause the tranny isnt pulling the engine back or b4 previous owner somehow put new bigger fan shrouds in, oh well i guess i'll wait till after the tranny is put back in
Re: belt changing
Post a picture of that area. I wonder if something is different.
Re: belt changing
It is probably because the trans is out of the car. The transmission creates more wight on the back of the motor causing it to sit normal. When you remove the trans, you need to brace the motor properly or it will literally tip to the front...
Re: belt changing
The transmission holds the engine at a slightly downward angle. That is to say, the line that would represent the crankshaft of the engine it not parallel to the ground, the nose of the crankshaft is higher above ground level than the rear. The engine will sit flat without the transmission and the pitch stopping mont to hold it in this "slanted" position. Be careful that the radiator is not damaged by the engine unit hitting it if you get rough when installing the trans.
2007 GS 450h-Active Stabilizer/Radar cruise 1994 L Blue 3.70 VTD ASE Master Automobile ASE Advanced Level Specialist Toyota Master Diagnostic Technician (former life) |
Re: belt changing
if anything the shroud would be wrecked b4 that happens
Re: belt changing
here's the pics of the gap
Re: belt changing
Yep, that's way close. Just wait for the tranny =)
1994 SVX LSi - Black / Beige - 139k miles SOLD! 1999 Chevy Camaro Z28 - Black, 6-speed, hell of a ride. 2004 Chevy Silverado Z71 - Blue LT2 luxury package |
Re: belt changing
ya will be nice to get er up and running its been over a months since i bought it lol
Thread Tools | |
Display Modes | |
