Old 05-04-2009, 03:11 PM
Gamesy's Avatar
Gamesy Gamesy is offline
headlight oxidization
I was wondering if anyone has had this with their cars or not but if you did how did you clear up your headlights. I was looking into it and it seems that most methods use sand paper others just use a solution. I dont know which would be the best idea.
Old 05-04-2009, 04:18 PM
Re: headlight oxidization
Most everyone has this issue. I used CV Headlight Restorer it worked well and is pretty cheap, but you usually have to do them once a year or every 2 years.
Old 05-04-2009, 05:04 PM
Meguiar's PlastX here.
Old 05-04-2009, 06:49 PM
The different grades of sandpaper works the quickest and the best finish, but some of the solutions work like cutting compound, and they also give a good finish.
To get around re-doing the job it would be beneficial to remove the lamps and spray a few coats of UV inhibitor top-coat on the lenses. This will slow down the oxidation of the plastic.
You will probably still have to resurface them again in 5 years or so though.
Old 05-04-2009, 07:56 PM
redlightningsvx's Avatar
Collision Refinishing Tech
I sanded mine and used 3 heavy coats of PPg 3000 clearcoat which is hard as a rock and uv resistant. They looks as close to new from comparing them to Mike621's at Reading.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 05-04-2009, 08:06 PM
Yeah they looked good, I thought they were new.
Old 05-04-2009, 08:29 PM
Seth - how much sanding did you do and did you finish them smooth like you would even if you didn't paint them with the clear coat?
Old 05-04-2009, 08:31 PM
I sanded them a good bit with 600 wet to get most of the pits out of them, then I used 1000 & 1500 grit to smooth them up, Then I used a plastic adheasion promoter before I put the clear down.
Seth
Past subies:
Other toys:
Old 05-04-2009, 08:59 PM
Sounds good. They did look very good.
Old 05-04-2009, 09:03 PM
Thanks. I also used the CV restorer before last Reading and it lasted only 6 months. I stated how much I liked it during the raffle. But to each his own.
Seth
Past subies:
Other toys:
Old 05-05-2009, 06:02 AM
That sounds like the way to go Seth. Pure brilliance, if you'll pardon the pun. Any JDM cars I have had, and all waterfall grilles have been coated with clear coat from the factory.
This no doubt is for surface protection, but I wonder if they originally bothered to use UV blocking clearcoat? I think not. They did not bother with UV clearcoat on the mirrors, nor did they use it on the rear quarter plastic garnish. These are areas we all know tend to fade and go dull with age. A lack of quality control when dealing with outside suppliers going on here. They should have insisted on the specification of the paint used.
Old 05-05-2009, 08:14 AM
The only way to keep the polishing from yellowing again within 4-6 months is to spray them with UV resistant clear coat.
1985 Brat GL 138k
91 CRX Si 40k
91 CRX Si 155k
97 SVX Lsi 70k
2003 s2000
91 RT4WD 166K
Old 05-05-2009, 01:20 PM
Gamesy's Avatar
what places carry UV clear coat stuff?
Old 05-05-2009, 06:31 PM
Any autobody supply will carry clears just tell them exactly what you want. Almost any clearcoat today is UV resistant. I used expensive paint because I had some left over from my car which will last many,many years. You can also get some cheaper clears that will last a couple years but not as long. You pretty much get what you pay for. A good, cheap clear would be PPG's Shopline brand which is better than Omni
(cheap) but not as good as Concept (excellent what I used).
Seth
Past subies:
Other toys:
