Old 04-06-2009, 10:05 AM
Just ordered my Strong Arm Hood Struts
I will be doing the mod on my only set of hood struts and I wanted to see if there was any last minute advice or tips that may not be in the document? (I'm a little tired of the broom stick) And it seemed like a good idea to convert them to a standard gas strut rather than the oem. You all that have done this, what do you think, you like this mod?
Old 04-06-2009, 10:23 AM
Re: Just ordered my Strong Arm Hood Struts
We like this mod so much, that we sell them premade!
I have this mod on all of my SVXs and am VERY pleased with the results.
Old 04-06-2009, 10:59 AM
Damn it! If I had realized that I would have ordered yours. I am going to see if I can cancel my NAPA order.
Old 04-06-2009, 12:49 PM
Alcyone's Avatar
Alcyone Alcyone is offline
i dont know what the pre-made ones cost, but if there is a significant difference, i would go with self fabricating the a/m ones
you will need a few "heavier" tools:
metal saw, or handheld grinder w/ cutting wheel
-thats to cut the bottom bracket off of the stock strut
handheld/tabletop grinder
-to polish your cut, make it smooth/parallel with the other side
drill w/ metal drill bit (i forget the size)
-to drill the hole
thats about it, piece of cake aside from that grinding work.
one tip that i felt was SORELY needed in the how-to, but somehow ommited:
the order of re-assembly
whatever you do, put the bolt with the ball on the end, back into the hood FIRST
then attach the bottom bracket
and only THEN, do you 'pop' the strut onto the hood bolt
i (foolishly) left the bolt in, and then tried to thread it in...
disaster
Old 04-06-2009, 01:01 PM
svxash's Avatar
svxash svxash is offline
What was the correct part # for the struts? I have an extra set that I also want to convert.
1997 Boudreaux LSi
1994 SVX LSi(SOLD)
Kool Blue air filter, 4500k HID's, airbox mod, Hella horns, WRX 6 disc stereo, Infinity Reference and Clarion Pro Audio speakers, Infinity basslink sub, ECUtune Stage 1v5, ECUtune TCU, Power mode mod, Mad muffler mod v1.3
Old 04-06-2009, 01:09 PM
Alcyone's Avatar
its in the how-to writeup
however, it is to be noted that they are actually about an inch shorter than the stock struts
this causes the hood to be "open" at a slightly sharper angle than the stock struts would provide
not a big problem i guess
but
with the massive number of a/m struts available, dare i say there might be an even more fitting set out there?
unfortunately they are not searchable by length open/closed or stroke, or anything technically useful like that
-at least not by me, or the napa guys i talked to
Old 04-06-2009, 01:11 PM
I use SPD/Barnes hardware when doing the retrofit, as per LetItSnow's recommendation. I have been very happy with the results and their quality.
SPDhardware.com
GSNI225090
(You can also get them in Stainless. :-D)
Old 04-06-2009, 04:31 PM
Alright, order cancelled. I will be ordering yours Mike as soon as I have verfied that I haven't gotten charged by Napa. That is $60 for the pair right?
Old 04-07-2009, 10:15 AM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
I just installed the NAPA struts, same part number as the How_To but now named Balkamp Turbo Struts. They cost $27.50 each but the conversion was straight forward and they work great. Hardest part was getting the ball out of the SVX struts. My vise is a cheap one so I had the cut it them out with a dremmel. Definately install the bottom bracket before you connect the strut to the ball. Mae that mistake too.
Gene
Gene and Ben
Old 04-07-2009, 10:25 AM
$60 plus shipping, or I can bring them to Reading for you. We will need your old hood struts for core.
Old 04-07-2009, 12:22 PM
stuartracing stuartracing is offline
Are these a bolt in deal, or does it include some fabbing....
Old 04-07-2009, 12:43 PM
This is a bolt in product.
There is a core charge of $15 that applies, but is refunded as soon as we recieve your old struts.
Old 04-07-2009, 12:48 PM
kwren's Avatar
kwren kwren is offline
This is just a suggestion to improve the great hood strut rebuild process that Mr yourconfused came up with.
http://ourlifeline.net/yourconfused.htm
Might help mike as well.
I love the way mine work!
Keith
Old 04-07-2009, 12:54 PM
Alcyone's Avatar
I think an overhaul of the document thats in the how-to docs is in order
and this other link that was posted for a seperate deserves some investigating, if only to find the correct length/stroke of strut
Old 04-07-2009, 01:01 PM
Thumbs up Re: Just ordered my Strong Arm Hood Struts
Keith
Good suggestion Keith.
I may implement this after checking it out.
