Old 03-08-2009, 10:45 PM
Green1995SVX's Avatar
Re: Pic's of my New Murano's
Looks great!
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 03-08-2009, 10:48 PM
Jeremy'sSVX's Avatar
Jeremy'sSVX Jeremy'sSVX is offline
Send a message via AIM to Jeremy'sSVX
Looks great!
Thanks!
Originally Posted by SSSVX View Post
This wheel looks nice on SVX.
How many lbs heavier compare to the stock wheel?
I'm not sure? they're not much heavier just from lifting them to mount them? Close to the same.
Originally Posted by Mensaf View Post
What sizes are you running?
Tire? 225-40-18
Wheels? 18's
-Jeremy-
1994 Barcelona Red LS 97,xxx miles
- JVC Indash head unit, polk 6.5's, 6X9's, 2" tweeters, and 8" JL audio subwoofer run off of MA Audio M589I amp. Fiberglass Front splitters molded in, Shifted back stock spoiler, & repainted minor faded parts (Mirrors, rear quarter garnishes),18" murano 5-spoke wheels w/cooper zeon 2xs tires, '97 grille
Old 03-09-2009, 08:03 AM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
*paste from previous thread*
I swapped my wheels back to the stock ones, so i figured it might as well get a quick measurement of weight. The stock rim has the Continental Contiextreme Contacts 225/50/16 while the Murano rims have General Exclaim UHP at 225/40/18.
I basically used a bathroom scale that I stepped on first. Then I held each wheel while getting back on the scale.
The results are:
Stock rim with tire: 44lb
Murano rim with tire: 47lb.
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 03-09-2009, 08:12 AM
Turbone's Avatar
Turbone Turbone is offline
Send a message via ICQ to Turbone Send a message via AIM to Turbone Send a message via Yahoo to Turbone Send a message via Skype™ to Turbone
It looks very nice.
Looks like its starting to be a fad
I also got my wheels from Dayle.
I have real wide tires on, 245/45.
Yes they rub, but its actually the fender liner they rub on.
I need to adjust my camber a little.
Prime Сasual Dating
Old 03-09-2009, 08:46 AM
wawazat??'s Avatar
Yeah, I'm still around
They look good though in general I find 18" (and larger)wheels not to be my taste on the SVX. I do think heavy/wide spoke wheels look good on the car.
Originally Posted by Jeremy'sSVX View Post
Do you have any problems with yours rubbing? My right rear rubs when i hit a bump or corner hard to the left. Do you know of anything to fix that?
Thanks!
The rubbing is due to the offset on these wheels being incorrect for the car. Nissan uses 35mm-38mm offsets on their cars. Subaru uses 55mm offsets. Their is lots of conjecture on whether this is a problem for the bearings (search is your friend) but the most prevalent issue is tires rubbing as the wheels don't fit in the wheelwell as FHI intended. For comparisons sake, I use a wider wheel and tire combination with higher offset (17x8.5" wheel, 48mm offset and 245/40-17 tires) with no rubbing even under heavy cornering (autocross). Others here in this thread make mention of changing the suspension settings (adding negative camber) to reduce the noise. This will increase your tire wear on the inside shoulder. I'm no fan of adjusting suspension out of factory recommended settings to make wheels that don't fit correctly not rub. Seems like a Band-Aid fix to a poor fitment issue to me.
Todd
Down to none
Old 03-09-2009, 09:01 AM
LetItSnow's Avatar
Still Cant' Say the Z-Word
Real tall, too!
Old 03-09-2009, 02:44 PM
Ownbot's Avatar
Ownbot Ownbot is offline
I'm the anti-do-gooder
I love those wheels on a SVX!!
Old 03-09-2009, 03:54 PM
Schralper's Avatar
Schralper Schralper is offline
Originally Posted by LetItSnow View Post
Real tall, too!
huh? i don't know about real tall.
245/40 is only .5" taller than 225/40R18
but i'll grant you, that's why i'm waiting on my 225/40 BFG KDW's for my murano rims. Which i got for $100 total, off craigslist. which is good cuz the rubber's gonna be $800 mounted and balanced.
FYI a 245/40 is recommended for 8-9.5" rim. Murano's are 7.5"
WFO!
http://www.cardomain.com/id/Schralper
"You all laugh cuz I'm different
I laught cuz you're all the same."
Old 03-09-2009, 04:59 PM
Don't waste your money on kdw's.
Get cooper zeon 2xs tires. They're like $100 a piece and they're very comparable.
Thats what i got and they're amazing.
At least look into em!
-Jeremy-
Old 03-09-2009, 05:09 PM
Schralper's Avatar
i've looked at a few different tires. i really like bfg's having some on my trucks. overall they wear gr8 and good construction.
i've had coopers too. but they're a lil noisier and grip could be a lil better, but wear is good.
i'm thinkin these are gonna be the last set of tires i'll be buying for a LONG time, considering this depression. these are summer tires.
i've got hankook ipike winter tires, which are way better than studded tires, on oe rims.
WFO!
Old 03-09-2009, 08:30 PM
SubaRyu's Avatar
SubaRyu SubaRyu is offline
Domo Arigato
Yeees those Murano rims look great. Good thing about this wheel design is, it doesn't look aftermarket. At least in my opinion.. I've had them on my car for about 2yrs by now. I don't hear any rubbing noise from rear. I heard it when my inner fender was coming off though.
-Ryu
Links:
2004 Honda S2000 (2008~)
1992 Subaru SVX LSL Liquid Silver (2007~2008)
1996 SVX LSi Bordeaux Pearl (2006~)
2002 Lexus IS300 Sportcross (2005~)
1992 Subaru SVX LSL Pearl White (2001~2005)
1994 Mercury Sable GS (1999~2001)
1/43 Scale SVX Models
[SIGPIC][/SIGPIC]
Old 03-09-2009, 09:03 PM
SubaruSVXCrazy's Avatar
SubaruSVXCrazy SubaruSVXCrazy is offline
AWD..... NOTHING COMES CLOSE
Send a message via AIM to SubaruSVXCrazy
Good deal guys, very nice.
1992 Subaru SVX LS-L #5045 Dark Teal
1992 Subaru Loyale Wagon Gray (SOLD)
1999 Subaru Impreza 2.5RS Coupe Black Ruby (SOLD)
1969 Subaru 360 Deluxe Ivory White
2005 Subaru Impreza WRX STi World Rally Blue
1993 Subaru Legacy L Wagon Teal Metallic (SOLD)
1998 Subaru Impreza 2.5RS Coupe Rally Blue Pearl
[SIGPIC][/SIGPIC]
Old 03-09-2009, 10:02 PM
i do like the look, but when your bearings fail, i won't expect anything other.
1985 Brat GL 138k
91 CRX Si 40k
91 CRX Si 155k
97 SVX Lsi 70k
2003 s2000
91 RT4WD 166K
Old 03-09-2009, 11:37 PM
Turbone's Avatar
The bearings fail with the stock wheel setup too, ya n00b.
Prime Сasual Dating
Old 03-10-2009, 03:26 AM
OzBloke's Avatar
OzBloke OzBloke is offline
Really nice rims!
1992 SVX 120,000kms
STi Rims, Dents removed, Respray, Trans cooler
