Old 01-02-2009, 02:13 PM
doug maire doug maire is offline
keystoneaz
Stereo Connector
Does anyone have the connector for the stock radio on a 1996 SVX LSI.
It includes the CD Player that is mounted below it.
My son had replaced the original radio with an after market but I would like to replace it with the original radio. Problem is he cut the wires off right at the back of the connector so theres no way to splice them back together.
Old 01-02-2009, 03:06 PM
Re: Stereo Connector
Yes, there is someone here who sells them. It is a great product. The members name is SVXdc. Do a search and you will find the thread where he explains how to order and the products that he sells. Good luck.
Old 01-02-2009, 03:27 PM
or just find a kid on here who wants to put in a aftermarket, and tell him to cut off the original connectors with 4 inches wire and send it to you.
1985 Brat GL 138k
91 CRX Si 40k
91 CRX Si 155k
97 SVX Lsi 70k
2003 s2000
91 RT4WD 166K
Old 01-02-2009, 04:28 PM
SVXdc's Avatar
SVXdc SVXdc is offline
Radio wiring harness guru
Except the "kid" will have to reach inside the dash opening to solder or crimp to the remaining portion of the car's wires.
It's better not to cut off the factory harness. Using one of my harnesses makes the job much easer — you can do all the soldering or crimping on your workbench, and you'll be able to easily switch back to stock or another aftermarket radio in the future.
David C.
Old 01-02-2009, 05:18 PM
IceBlade's Avatar
IceBlade IceBlade is offline
Send a message via MSN to IceBlade
When I did mine I left the connector on. I just stripped the wires behind the connector - took off about 1/16 inch - connected the aftermarket stereo and wrapped it up nicely. If I ever wanted to go back to stock all I'd have to do is take off the electrical tape, remove the aftermarket head unit, and plug the stock one back in.
Old 01-02-2009, 06:38 PM
keystoneaz
Thanks to all for your response. I will opt for the new replacement harness from svxdc.
Old 01-03-2009, 11:32 AM
When I did mine, I plugged in the new harness and put the stereo into the slot. If I ever want to sell the car, I will unplug it and plug in the OEM unit and it will be like nothing happend at all.
I would go with a unit from SVXdc.
Old 01-04-2009, 12:36 AM
JaySVX's Avatar
JaySVX JaySVX is offline
I installed an aftermarket system in my car. While the harness would be ideal, I cut mine and still had next to zero room to pack the piles of wires in behind the new radio. It's not always an option.
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
