Old 12-18-2008, 02:44 PM
s'ko s'ko is offline
is this short block dead?
I just got an SVX shortblock and I noticed that one of the piston walls has a nick and corrosion at the top of the cylinder. It is the middle piston on the pass side and it goes all the way through the aluminum and hits the metal sleeve. The sealing surface on the cylinder is gone so the only way to use the block is to repair it.
I will take pics tomorrow and post it so you can see what I am dealing with.
I figure my options are
1) use some metal based epoxy on it and hope for the best
2) take it to a welder get it welded
3) resleeve the engine for a EJ20 92mm piston and get more sealing surface back.
has anyone tried using JB weld or the like for an application like this?
Would there be any benefits from using a 92mm piston?
Thanks for the input
BW
Old 12-18-2008, 03:11 PM
Re: is this short block dead?
resleeving is going cost a hell of a lot, but more than likely going to be the only way to fix the block... I would never use any resin or apoxies on a crack in a block... Just asking for a headache
Old 12-18-2008, 03:48 PM
Talked to a auto machine shop who recommended a welder in the area who does a lot of work with engine.
Welder said he could weld it up. Hopefully this will solve the problem.
Charging me $45 to do it.
BW
Old 12-18-2008, 04:01 PM
siceclipse's Avatar
siceclipse siceclipse is offline
i dont see this ending well
Mike
1992 SVX LS-L Pearl White 102,000 miles (Gone)
2005 Evolution 8 SSL Tarmac Black (new daily)
1995 Eclipse GSX Durango Copper Pearl (teh beast)
276awhp/280awtq @ 18psi (560's inj)
260awhp/260awtq @ 17psi (stock inj)
Old 12-18-2008, 04:42 PM
why?
Please explain..
thanks
BW
Old 12-18-2008, 06:49 PM
svxpert svxpert is offline
BW
sound good. then all you have to do is mill it flat. do you have any pics of the damage? get some before and after for future reference.
Old 12-18-2008, 06:52 PM
welding is a solution, but AL takes a lot of heat... Make sure the cylinder walls do not get warped or damaged in the process and like Mike already said, that the deck surface is milled
Old 12-18-2008, 09:50 PM
liamrh's Avatar
liamrh liamrh is offline
Yeah, you could see some weird camming in the cylinder with that type of repair.
