Old 12-18-2008, 02:32 PM
davew833 davew833 is offline
ECU swap: OBD2 for OBD1?
Has anyone thought of doing this? Would it be plug and play, or is the wiring harness/connectors different for OBD2? I'd like to run an ECUtune Stage 1 chip in a '96, but of course it's not made for OBD2. Could I swap my ECU for a pre-96, I wonder?
davew833@yahoo.com
Former 6-time SVX owner
Old 12-18-2008, 03:12 PM
Re: ECU swap: OBD2 for OBD1?
change the TCU as well.. It can be done.
Old 12-18-2008, 07:28 PM
stiguy's Avatar
stiguy stiguy is offline
what about the other way around?
Old 12-18-2008, 08:13 PM
No, there were additions to the OBDII systems that the OBDI's do not have. BUT everything from an OBDI system is and should be present in an OBDII
Old 12-18-2008, 08:31 PM
SVX92-97's Avatar
SVX92-97 SVX92-97 is offline
Do you need to swap the TCU when swapping a OBDII engine and tranny into a OBDI car. My OBDII tranny shifts smooth as butter in my OBDI car. Just thought Id ask
1995 POLO LSI 76K MILES SOLD
Old 12-18-2008, 08:37 PM
No because you are using an OBDI ECU... There is communications beyond the OBDI standards between the OBDII ECU and TCU. If you change one, it is suggested you change the other as well.
Old 12-18-2008, 09:08 PM
LetItSnow's Avatar
Still Cant' Say the Z-Word
What about inspections? The ECU will probably have to be swapped back to OBD-II right? (My '92 cares not; I'm just in on this one for the tech.)
Old 12-18-2008, 09:18 PM
TomsSVX replied to me privately and told me the OBDI/OBDII wiring/connectors were different. Can anyone confirm? I trust his expertise, but I'd love him to be wrong in this case.
davew833@yahoo.com
Old 12-18-2008, 09:45 PM
The OBDI- harness is comprised of 4 seperate plugs. The OBDII harness is one single plug... There must be a jumper harness made.
Rob, yes you would need to jump back to OBDII ECU's for inspection considering most scan the ECU through the diagnostic ports... Which will not be functioning w/ an OBDI ECU
Old 12-19-2008, 03:30 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Does anybody have a good photo of an OBD2 SVX ECU with the lid off.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 12-19-2008, 06:16 AM
LetItSnow's Avatar
Originally Posted by TomsSVX View Post
...yes you would need to jump back to OBDII ECU's for inspection...
I kinda figured that the diagnostic port wouldn't be there but I wasn't sure if there was a year that inspections instituted connecting to OBD-II, or if it was all OBD-II cars.
Old 12-19-2008, 06:59 AM
If I have an extra ECU ill open it up
