Old 11-15-2008, 08:02 AM
dakos dakos is offline
engine cooling fans running nonstop
hi,
can anyone please let me know where are located the temperature sensor(s) or the thermoswitch that commends the fans
biiiigggg tahnks!!!
Old 11-15-2008, 08:18 AM
Re: engine cooling fans running nonstop
Could be a sticking relay, bad speed sensor, bad temp sensor, or you just have the a/c on?? Any check engine lights comming on??
Old 11-17-2008, 09:43 AM
hi,
my speedo stop working a week ago..but what has to do the speedo with the cooling fans??
Old 11-17-2008, 10:30 AM
The speed sensor is used to turn the fans off at speed. If it is malfunctioning, the ECU will trigger the fans all the time as a default setting
Old 11-17-2008, 04:13 PM
thanks a lot..i'll try to fix that speedometer issue first...
