Old 11-11-2008, 04:38 PM
kwren's Avatar
kwren kwren is offline
How in the heck...
do you get the fuel injectors to come off.
Not all together, but just one.
Thanks,
Keith
Old 11-11-2008, 05:53 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Re: How in the heck...
A lot easier than putting them back on without having a leak. Once you've removed the holder stuff the rail just slides out. If I remember right you need to take the bank off to be able to take one out of the holder for replacement. If you need to replace one I've heard great things about the places that will clean and blueprint the flow of 'em. Doesn't do much for performance but tends to up mileage enough to notice. Costs about $20 a piece. Might want to pick up a used set, send yours away (if you were planning on replacing one) that way you're not sitting SVXless.
Old 11-11-2008, 07:28 PM
kwren's Avatar
The Bank?
Holder stuff? Holder stuff fo all 3 at once? Holder stuff for one ejector?
Rail? Is that the whole kit and caboodle?
Thanks,
Keith
Old 11-11-2008, 07:53 PM
Hondasucks's Avatar
Subaru Technician
See attached PDF Looks fairly straightforward, but you will need to replace the O rings on any injectors you remove.
1986 VW Jetta
Old 11-12-2008, 01:52 AM
kwren's Avatar
Thanks!!
Keith
Old 11-12-2008, 07:32 PM
immortal_suby's Avatar
Thread Killah
I've never replaced an O ring.
You can remove individual injectors without removing the fuel rail.
Remove the electric plug and the 2 screws and pop off the cap, then twist the injector 90 degrees so you can get a large flat blade screwdriver under the plastic electric plug part and pry up very gently on it.
Locker Link
2015 BRZ Limited 6MT
Old 11-12-2008, 09:53 PM
Hondasucks's Avatar
Subaru Technician
I always do, that 99 cent O ring is a whole hell of a lot cheaper than replacing your car when it catches fire! The fuel is under high pressure in the rail, so any leak and you'll have a nice atomized spray that is very readily ignitable, I wouldn't risk it.
Also from a work standpoint, if you are going to have it apart, it's a lot easier to replace them while you have it apart and not have to f**k with it later, than have it leak and then you have to take it apart and fix it.
1986 VW Jetta
Old 11-13-2008, 07:48 PM
Thread Killah
Are the O-rings a subaru part or something I can get at an autozone.
Locker Link
Old 11-13-2008, 10:03 PM
don't forget to clean up the bosses for the injectors.. They can be corroded ad can ruin a new o-ring. Also use some lubricant to help slip them into the bosses.
Old 11-14-2008, 12:13 AM
kwren's Avatar
Thanks.............
kwren's Avatar
Thanks.............
Old 11-16-2008, 09:25 AM
Thread Killah
Originally Posted by kwren View Post
Thanks.............
no, it was a question
are these shelf items at local parts stores or subaru order?
Locker Link
Old 11-16-2008, 10:51 AM
Hondasucks's Avatar
Subaru Technician
You might be able to get them at autozone, I don't know what they cost from Subaru, my power steering o-ring was like 2 bucks.
1986 VW Jetta
Old 11-25-2008, 01:47 AM
kwren's Avatar
Sorry, guess it was past my bedtime. LOL
I would get them from Subaru because of the importance of having the exact size, but that is just me.
Old 11-25-2008, 08:19 AM
If you don have a Subaru Dealer close enough, you can get them from a Nissan Dealer as well... Thats what I did when I needed them in a hurry. They can be picked up at local parts chains if you ask them to list the 240sx injectors, but my experience with the cheap ones is that they require even more diligence installing
