Old 11-13-2008, 02:42 PM
svxash's Avatar
svxash svxash is offline
Re: Finished my power mode mod
You can use the dry transfer lettering that hobby shops sell for model trains to do the lettering and put a flat clearcoat over it. The font which most resembles the lettering on the dash buttons is Gothic Condensed. I already have some of this on hand.
Here is a link to just on of the many sites available to purchase lettering
http://www.hobbylinc.com/htm/woo/woomg738.htm
And if you do it right, it may just end up looking like this...
I thought about doing that but I want it to be back lit like the rest of the buttons. I have some ideas in the works and I'll post if they work out.
1997 Boudreaux LSi
1994 SVX LSi(SOLD)
Kool Blue air filter, 4500k HID's, airbox mod, Hella horns, WRX 6 disc stereo, Infinity Reference and Clarion Pro Audio speakers, Infinity basslink sub, ECUtune Stage 1v5, ECUtune TCU, Power mode mod, Mad muffler mod v1.3
Old 11-14-2008, 01:08 AM
Banned
lol.... I looked at the switches today... I think I might be able to just pull it off with a lit push button one... shame they only came in red!
I'm just curious where did you tap the power from?? did you wire directly to the battery?? or tap into something close??
Old 11-14-2008, 04:51 AM
For the "power mod" he didn't need to get power. All he needed was to provide a ground to one of the TCU pins.
Old 11-14-2008, 12:02 PM
Francis Francis is offline
i think he meant about the green illumination
Edit : oh ...i just read the other reply...tricky, i thought i was true !!
Claret 92 Ls-l R.I.P - 24XXXX - kms "april 2008"
rest in pieces
Ebony black 92 Ls-l Alive - 25XXXX - Quick change, Powermod , Alternator Mod , audiobahn 1300 watt ach ,exile 800 watt peak, jackhammer 12" 300 watt rms, polkaudio 6 1/2 compoment. kenwood dvd\nav . radar detector.small car lens and grill
Old 11-14-2008, 05:29 PM
Wikedjuggalo's Avatar
Rebuilding
I was going to put mine on the other side but after deciding against it because of the spot. Nice job and I like it. Mine is on the side of the steering way.
Old 11-17-2008, 11:07 AM
svxash's Avatar
So I'm almost done. I added a green 5mm LED to the switch. I wired the ground to the switch and the power to the power feed to the radio. I cut some grooves in the switch so the wires would be recessed. I thought about trying to run the wires on the inside of the switch but decided on the outside in case I want to change colors and then I wouldn't have to take the switch apart to do it. I used a 5mm green LED from Radio Shack #276-304 and added a 330 Ohm #271-012 resistor to it to bring the voltage down.
1997 Boudreaux LSi
1994 SVX LSi(SOLD)
Old 11-17-2008, 05:56 PM
Banned
can you take a picture of the whole button assembly put back together before you put it in the car? I'm curious exactly how it all worked out where you fit everything, I haven't pulled mine apart yet so I don't know exactly what I'm looking at in your pictures. Thanks! where did you draw the power for the led?? is it just hooked to the power coming into the switch or is that what you hooked directly to the radio power like you said??
Old 11-17-2008, 07:33 PM
WestmonsterSVX's Avatar
WestmonsterSVX WestmonsterSVX is offline
should have filled up a little more before the picture...
Old 11-17-2008, 08:38 PM
svxash's Avatar
Just topped it off tonight. $1.89 for premium. Only took 9.7 gal as my fuel gauge is starting to go bad and reads wrong.
1997 Boudreaux LSi
1994 SVX LSi(SOLD)
Old 11-17-2008, 08:55 PM
Banned
wow... premium below 2 dollars some places!? I think I'm getting happier by the day... when I heard of regular dropping below I had good feelings!!
Old 11-19-2008, 05:28 PM
svxash's Avatar
Well I did some lettering on the switch today. I went to the craft store and bought a Testors decal making kit and made one that says power. I scraped off some of the black material on one of the factory switch covers and placed the decal over it. I then touched it up with black model paint. The decal I made was black with white lettering. It doesn't look perfect but I can live with it for now as it doesn't look too bad from a seated position.
power decal
installed
backlit
1997 Boudreaux LSi
1994 SVX LSi(SOLD)
Old 11-19-2008, 06:06 PM
Looks great!
Old 11-21-2008, 04:35 PM
Banned
how is it lighting up the words??? I'm confused if you just put a decal on the front of the button how the light would shine through the black plastic... aren't the other ones kinda clear through where the white lettering is on the buttons?? gosh I really need to get home so I can look at my buttons and figure this out instead of asking a lot of these questions I could probably answer myself, but it's just driving me crazy with anticipation!!! I'm stoked!!
Old 11-21-2008, 04:47 PM
processengr's Avatar
Nice work!
Cheers! Gordon
1992 Ebony 251k 444 SOLD
1999 Silver SLK230 134k SOLD
1997 Green Outback 137k SOLD
2013 Honda Accord I4 SOLD
2015 Subaru Crosstrek 30k
2018 Tesla M3 30k
Old 11-21-2008, 09:21 PM
svxash's Avatar
If you take one of the switch covers off and look at it from behind you will see that the area where the lettering is printed on is opaque allowing light to pass through. I just scraped off the factory lettering and placed a decal over it. I'm at work until Sun but I will try and post a pic of a switch cover when I get home.
1997 Boudreaux LSi
1994 SVX LSi(SOLD)
