Old 10-04-2008, 05:32 PM
Mensaf's Avatar
Mensaf Mensaf is offline
What do you mean wrong SVX?
Well, the diff isn't binding...
I was pretty sure my diff was starting to bind, but I just did a slew of tests, and found that this isn't the case. It's a cracking sound when I turn the wheel right to a certain point. Is there something in the steering I should look for?
Old 10-04-2008, 06:22 PM
gstape gstape is offline
Re: Well, the diff isn't binding...
Without hearing it I would guess one of the bearings on top of the strut is going bad, and the spring is maybe coiling and then poping. Its a guess, although I've had a similar issue on an impreza.
Old 10-04-2008, 06:36 PM
Ditto. Put the car on jackstands, put the key into the off but not locked position, and then go the a front wheel and turn it by hand. (not spin, turn like the steering wheel does) and watch the top of the spring. Repeat on the other side. Make sure you turn the wheel all the way left and right.
Old 10-04-2008, 07:45 PM
JLHollowX13's Avatar
JLHollowX13 JLHollowX13 is offline
Send a message via AIM to JLHollowX13
idk if this is what you are describing, but when my front cv axle was bad i would hear popping when i turned certain ways. if you jack it up to check the suspension you should also check all cv boots for tears.
1992 silver/black LSL - 142,xxx miles
power mode switch, ecu crush, intake silencer removal, ecutune, B&M transmission cooler
1971 toyota landcruiser - project.... someday
Old 10-04-2008, 08:33 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Usually its a loud clicking sound that gets faster as you go faster, or more intense when you turn more.
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
