Old 05-24-2008, 12:21 AM
Originally Posted by SVXRide View Post
Look closely. The x axis is mph, but the y axis is AFR.
-Bill
So I was thinking that the lean condition happened at the shift poinnt of 35 mph, the 1-2 shift. Not the iris opening at 3500rpm. hmm.
blk 92' LSL w/ average mods
Old 05-24-2008, 05:55 AM
wannarace928's Avatar
wannarace928 wannarace928 is offline
Send a message via AIM to wannarace928 Send a message via Yahoo to wannarace928
Classic SVX
My car shifted from 1st to 2ed. It would not shift into 3ed, it evidently hit the rev limiter and would not make the shift - which you can see on the graph there at the end and hear in the video.
The only problem the car has is, it gets a little oil blow by, probably caused by the rings.
The car is stock except for the 4.44's, and a custom exhaust.
1992 Subaru SVX 5spd
1998 Pontiac Firebird Formula
1999 Chevrolet Camaro SS
2009 Subaru Forester - Mileage Junky
2009 Pontiac G8 GT
2017 Ford Mustang GT 6spd
Old 05-24-2008, 07:22 AM
poweredx2 poweredx2 is offline
Why wouldn't the car shift to third,do you have any tranny problems numbers are very low even for a stock svx.
Old 05-24-2008, 07:31 AM
This should be ok for the people that have a fwd svx.
Old 05-24-2008, 08:21 AM
Classic SVX
The car does not have any tranny problems. I drive it every single day and have taken it to the dragway, it has never done anything like that.
The guy that did the dyno said it hit the rev limiter.
2009 Pontiac G8 GT
Old 05-24-2008, 08:30 AM
redlightningsvx's Avatar
Collision Refinishing Tech
Was the test done in D or slapped through gears?
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 05-24-2008, 01:01 PM
immortal_suby's Avatar
Thread Killah
It should have shifted anyway - whether in 1,2,3 or D it should force a shift when it hits the rev limiter. Unless there is something different with your 4.44 swap.
Locker Link
2015 BRZ Limited 6MT
Old 05-24-2008, 04:48 PM
If you "bump" shift it from 1,2,3, then D it revs to i think 6500rpms but when in D the revs happen sooner then maxing the revs by bumping the gears
Seth
Past subies:
Other toys:
Old 05-24-2008, 05:07 PM
It could be that the awd was confused by the dyno,just food for thought.
Old 05-24-2008, 07:25 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Yeah, I basically disregarded the mph scale, as the portion of the plot at which the AFR goes super lean looks very similar to when the iris opens.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 05-24-2008, 08:29 PM
Classic SVX
Well I just got home from a long trip in the SVX after the QC was installed (and quite a bit of playing ). And I must say I am quite impressed and happy with it. It is incredibly smooth and makes the car feel faster. The shifts are firmer but not overly firm. I can't wait to get the "AFTER" dyno results to see the differences.
And I believe it was in "D" for the dyno runs. I will ask the guy that did it either tomorrow or monday when it goes back on the dyno.
2009 Pontiac G8 GT
Old 05-25-2008, 01:08 AM
Object of the exercise.
It is always possible to achieve a design provided a specification is set down. I now gather that a major desire, is to cut or reduce the level of engine torque control applied during transmission shifts.
Control is signalled from the TCU to the ECU via a cable connection in the loom between the two units, i.e. (B68) TCU - 16 to (B59) ECU - 20. The signal is normally at 5 volts and it would appear that reducing this signal will cut engine torque. Therefore a resistor in this line, with a normally closed switch or relay across it, should provide a means of a selectable cut or reduction in the normal degree of torque control.
Control of transmission line pressure should be possible by inserting a resistance in the green yellow control line TCU to transmission, at the connection on the top of the transmission (T2) 7. Added resistance should increase pressure and again a relay or switch across the resistor should provide control.
Automatic control of these functions could be via a pneumatic switch, as per the Small Car shift kit, or other means directly from the TCU, e.g. a diode bridge providing an isolated circuit from all or any shift solenoids.
Rocket science is not involved, the major factor involving test and experiment. That said, Phil after completing his work, will be able to offer the exact and proper solution which will be without compromise, or add on modification and without doubt must be the correct way to go.
Old 05-25-2008, 02:04 AM
Nomake Wan's Avatar
Retired
Like this?
Old 05-25-2008, 02:29 AM
Originally Posted by Nomake Wan View Post
Like this?
No, no. N.B. --- "Therefore a resistor in this line," My text is clear, the resistor should break the line. Parallel connections to the existing circuit will not achieve this.
Old 05-25-2008, 08:52 AM
Thread Killah
provide control.
Trevor,
Good to have you back
With the engine operating at a higher torque during the shift will there be a risk of damage to the transmission?
Locker Link
