dyno on friday.... I should be able to do some fooling around then..
Former: 1994 Barcelona Red(x2), 1995 Brilliant Red, 1992 Liquid Silver, 1992 Ebony(x2), 1992 Pearl White (x2) Current: 2017 Ford Raptor 2017 Kawasaki KLR 1995 Guards Red Carrera 1995 Spec-ish Miata - track car 1957 CJ-5 |
From what sicksubie told me the cobra mustang guys have very good success with this kit including on cars upgraded to whipple chargers. The way it works is the nozzles are put pre-blower and point directly at the screws so the water/meth is sucked up and put through the compression phase where I'm sure it is COMPLETELY vaporized. The cobra mustang racing crowd is serious enough that I bet if the general consensus there is that it works great that it probably does.
I'd still like to see the spray pattern. Simple designs like this kit are often good for specific applications, but with a little bit of tweaking can do wonders in other areas. |
Here is a pic of where I mounted the jet..... For those not familiar with the stage 3, this is the bottom of the TB adaptor. When the jet is plugged in it will be aiming directly at the blower screws...
When's it scheduled for some dyno time?
friday.......
I put the medium jet on too.... I am driving it tomorrow and I will let you know of any butt dyno sensations....
first link just spins...second link is fine...is there going to be a movie of the car actually running with the methanol "spraying"
-Bill
I suppose i could do that
car shuts off under boost and is running 10.0 on the afr under regular driving conditions....... Going to check the TPS so try to correct the AFR and put on a smaller jet... Also, what about the thought of not enough spark to burn everything I am dumping in the motor now? Could that be a cause of it shutting off? I do literally mean the car shuts off 100% while you are moving if you floor it and cross over from vacuum to boost...
#28
I went through 4 gallons of gas on a 20 mile round trip this morning.....
#29
after you check tps... did you do anything with the heads?? that could cause it. next I would look at fuel, something could certainly be wrong with your fuel system. Goodluck, hope you figure it out
-Mike ECUTune2v7 - 4.11 5 Speed - Sprung 6 Puck Clutch - D&S Rotors - SS Brake & Clutch Lines - HKS Panel Filter - HeaderBack Exhaust -80GB Hard Drive - GroupN Engine Mounts - - some other "tricks"
[SIGPIC][/SIGPIC] In progess: track down mystery noise <-identified, paint the new dash, get better pic Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not - Next Oil change: Purolator L30165 Member #995 | My Locker | My New Locker Catch you next at: ? Auto-X ? Last edited by Speedklix; 03-09-2008 at 11:26 AM. |
#30
going to go check the TPS in a minute here.....
