Old 10-22-2007, 03:45 PM
porschekiller porschekiller is offline
Banned
Exclamation custom crank
lunati will take the stock forged crank and customize it up to 3.82 inches for a sqare bore and 4.3L
Originally Posted by crazyhorse View Post
From what I've seen of the EG33's engine block, the open deck design may be the limiting factor in boosting it. The cylinders in an open deck block tend to "squirm" under boost. "O" ringing it will help, but to get the numbers you're talking about, I'm not sure that'd be sufficient.
Yes stroking the EG33 would only involve the crank & rods. The $64 question is, where would you source the crank? Are you saying that the Porsche engine has the exact same bearing spacing/diameter? The thoughts of an EG37 are VERY intriguing.
Old 10-22-2007, 03:46 PM
Evil One Evil One is offline
Pinto Boosting Freak
Send a message via AIM to Evil One Send a message via MSN to Evil One Send a message via Yahoo to Evil One
Is there enough room at the base of the cyls for a stroke that long... or in the crank case?
Thats close to a .87" stroke increase.
Jim
1992 Dark Teal LS-L with 4.44 swap. NC Plate "EVIL I" *Dont Fear the GEAR*
1977 Ford Pinto baby blue with 79,000 miles
Old 10-22-2007, 04:03 PM
Originally Posted by FOMOGO View Post
OK... are we talking crank or wheel hp here?
Jim
I dunno about others Jim, but I am talking about theoretical engine output, at the crank.
There is little point in talking wheel horsepower. This will vary depending whether an auto or manual box is used.
Engine output will be what it is, based on the quality and diligence of the build.
Old 10-22-2007, 04:13 PM
I was assuming a very worked over head.
It is hard to ballpark theoretical power numbers without airflow potential.
My highly reworked heads and cam swap flows more air than your theoretical heads and cams.
Jim
Old 10-22-2007, 04:46 PM
Jim
Yes, agreed.
The increases in power my numbers represent are based on the OEM efficiencies of the SVX mill, as it is.
Going for bigger output than this will require getting everything right, plus improving flow dynamics.
Old 10-22-2007, 09:03 PM
svxual's Avatar
svxual svxual is offline
Tom's rad has double the channels. It is thicker than standard. This necessitated the purchase of two "skinny" fans and the thermostat controller, so the cost of these items has to be added to the mix.
The SVX oem fans were too deep to fit with the new thicker rad.
could you not just fit the existing fans to the outside instead of the inside??
Old 10-22-2007, 09:32 PM
sicksubie's Avatar
.87" does seem like a very large increase in stroke to me too.
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 10-23-2007, 02:47 AM
No. They are big. No room.
