IAC + throttle body cleaning.
I am having a rough warm idle problem ... I wanted to eliminate possible causes before I replace the ECU.
I have swapped in a working MAF, so that issue is eliminated. I have cleaned out the TPS, so, should I clean up the throttle body and intake air control? Or just stay far, far, away from these? Are there any pics posted of these objects, and a howto? |
Coolant Temperature Sensor?
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount (), sporting a "new" tail light bar, silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi |
i'v'e had rough idle issues ~ when car is warmed up - i was told that it was a bad coil. and then i replaced the engine (head gaskets blew) and more recently i am having rough idle as well...now it's rough idle even when on a cold start..?/ changed out half the ignition coils and i'm looking to do the other half tomorrow (hopefully).
i have no clue anymore at this point. if it's still bad when i change out the other side...i'm going to clean out the throttle body and IAC when it warms up a little more. out of curiosity. what are symptoms of bad plugs? i went to take out the ecu before to do the crush mod....and there was no bead to crush
1992 Subaru SVX LS~L Ebony Pearl 1992 Dodge Stealth R/T Firestorm Red 1992 Subaru SVX LS~L Pearl White 1992 Subaru SVX LS~L Ebony Pearl JDM 6MT/DCCD 2007 Subaru Legacy Spec B. Diamond Grey Metallic Last edited by DarknessofDeath; 03-24-2007 at 08:12 PM. |
If you look in my locker, you will find a how-to with photos of cleaning the IAC and throttle body.
Bill
Bill 94 SVX LE 130,000mi |
i happen to be looking at your locker a lot for the how to
1992 Subaru SVX LS~L Ebony Pearl 1992 Dodge Stealth R/T Firestorm Red 1992 Subaru SVX LS~L Pearl White 1992 Subaru SVX LS~L Ebony Pearl JDM 6MT/DCCD 2007 Subaru Legacy Spec B. Diamond Grey Metallic |
I'm glad you're looking. I hope you find it useful. Let me know if you have any questions.
Bill
Any update on this issue???
94 Bordeaux Pearl SVX Lsi B&M cooler with Aux ATF filter. QC Kit Plus 06 Sti Gold Wheels. SOLD 92 Claret WRX 5 speed ECUTune 1AV1 Gold STI Wheels & more. SOLD 92 Teal SVX LSL lowered with Konig. SOLD 92 Black SVX LSL with B&M cooler & Aux filter. Small Car Shift Kit. Gone 94 Red SVX L FWDwith LSL Leather Interior. SOLD 92 Teal SVX LSL....with B&M cooler & Aux filter. Small Car Shift Kit. SOLD 95 Polo Green........With Trany Problem. GONE Almost complete Rear Wheel Bearings Job with Pictures in my locker My Locker http://www.subaru-svx.net/photos/user.php?pearlm30 |
I cleaned up the throttle body and IAC .... All the hoses are good, and I added hoseclamps to kill any vacuum leaks.
But I am still getting rough stumbling when warm ... right at 60 MPH ... and now while waiting at the light. The waiting at the light stumbling goes away when I put it in neutral ... I am beginning to suspect a transmission problem. I opened the IAC a bit more to increase idle RPMs ... the 60 MPH stumble is less noticeable, but the waiting at the light stumble is now worse. Arrgh. |
news...
Any update on this...figure it out? I have the same issue
What about loose intake plenum bolts?
Are you getting any codes?
"The things you own end up owning you. It's only after you lose everything that you're free to do anything." 92 Pearl White Ls-l (138k) Euro Headlights & Blinkers, 97 Grill, Euro Tail Lights, SS Brake Lines, Stebro Exhaust, Slotted Rotors, Classic Registration 96 Legacy Outback (206k) 5-speed 2.2 Lightweight Crank Pulley, Group N Trans & Motor Mounts SOLD Wanted: Steering Wheel |
