Old 03-22-2007, 10:52 AM
hectormon's Avatar
hectormon hectormon is offline
Wafting Gas Smell
Alright, maybe I'm getting old and the old sniffer isn't working like it use to, but my wife has been driving my 96 Polo and when she last gassed up (hey, with the premium stuff, not Taco Bell), she noticed a puddle under the car that "kind of" smelled like gas. It was positioned slightly in front of the passenger front wheel. The car didn't change on performance, but this also coincided with the Check Engine light coming on. I checked under that part of the car, nothing but that annoying (small) gasket leak and a few drops of oil.
She drove it last night and claims that she is smelling gas, but I didn't catch whiff of anything but the pizza in the front seat.
Any ideas what it may be, what I should check?
1992 SVX Pearl
Quality is if the customer returns...not the product
1992 SVX Pearl (#2)
If it breaks in two parts...you can keep the parts
1996 SVX Polo
Judgement comes from experience... experience comes from bad judgement
SVX....collect all 5 (years)
Old 03-22-2007, 11:00 AM
budbaer's Avatar
budbaer budbaer is offline
Send a message via AIM to budbaer Send a message via Yahoo to budbaer
You could have a leak in your gas tank or a fuel line. The tank and the lines are presurized when the car is on. Turn the key to the on position, you don't have to start the car just to where the windows will work. Once the car is on then check under the car for a gas leak.
Old 03-22-2007, 11:37 AM
dcarrb dcarrb is offline
I had a loose/improperly seated hose clamp on the fuel filter outlet, allowing seepage under pressure. No puddle (and it would have been behind the front wheel, not in front), but I got a strong gas smell on start-up that dissipated completely once underway. Checking hose connections would be a good place to start.
dcb
Old 03-22-2007, 11:53 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
In front of the passenger's side front wheel? The only things that could be leaking in that area would be the radiator, the ABS box, or the power steering cooler lines (and they'd all have to find a way to "drain" to that spot). Moving back to slightly behind the PS wheel and you could have condensation draining out of the AC drain tube or a leak out of the windshield wiper fluid reservior. Hard to image gas getting to where you say the puddle was.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 03-22-2007, 12:17 PM
budbaer's Avatar
I think it was just a coincidence that there was a puddle behind the front tire. I don't believe there is anything fuel related in front of the front tire. Was it gas? Did you check to see what the puddle was? Another gas smell posibility is check to see if your gas cap is on tight.
Old 03-22-2007, 12:54 PM
Whoops, I was thinking the other side of the car. Pardon my inattention.
dcb
Old 03-22-2007, 02:04 PM
SVX_MY_BABY's Avatar
My gas line leaked above the gas tank. The gas never made it to the ground but there was always a faint smell until the leak finally got worse and was found.
