i have a feeling this may be an effect of E85 on our fuel systems or something like it. It would seem that the return line is clogged and not allowing sufficient pressure to return to the tank... Thus, cranking up the pressure on the in-bound line... Keep at it and let us know, I do not believe this is electrical, probobly mechanical hence the reason for not having any codes.
Tom |
by constricting the return line, there is a boost in outgoing pressure. That is the premise in which our FPR work. If there is a restriction to pressure and flow going into the tank (further back than you monitored) then it will still over pressurize the system. You need to monitor the fuel pressure at both the engine and at the tank and see if there is a difference
Tom |
there lies your problem... The SVX has a free flowing fuel system.. Meaning all the gas pumped in, if not used is then allowed to flow back to the tank... If you are intereupting the flow back to the tank, this is when the pressure will rise. You need a t connection and tap into the fuel system that way to test the pressure
Tom |
Check the spark plug leads
Had similar issue with mine, ended up being a faulty spark plug lead. When the leads where taken out to replace spark plugs.
Upon pushing the spark plug leads into the other various connectors - 2 of the leads worked fine when cold, but when warm/hot the lead contacts became open circuit, causing misfire & "hunting" revs (rev bounce & no speed increase due to misfire). What I noticed was that when lead was mated the pins sometimes get pushed out from rear of the plastic connector body - this was easily sorted by pushing pins as far forward with a small screwdriver & re-potting with a hi-temp silicon glue from the back of the connector body. It only took me 2 hours to find the problem!!!. Have fun Steve in New Zealand |
"the lines in the rear have been rerun with rubber due to corrosion I'd imagine." This is a practical issue and could involve/inicate a possible fault caused by others. Well worth careful scrutiny. All hands to the pumps. But you have the donkey work.
update
Today I checked the fuel pressure(perfect 36 lbs. with regulator unhooked) and engine vacuum(19 inches steady at idle).I also disconnect the 4 main engine harness plugs and cleaned them with electronics cleaner and I also cleaned the MAF plug and the TPS plug. I also tried resetting the ECU when all was done. All to no avail still. I'm wondering about a wire that has been severed and spliced at the ECU and now runs to one of the relays in front of the panel the ECU mounts too. It's on the far right big connector on the ECU and it is I believe the 3rd or 4th wire from the right in the front row of wires in the connector and it is orange. Any other ideas?? I guess I'll resort to coils next as it is one of the last things I haven't done yet. Any other ideas?
#28
probobly a weak coil then... I need to do coils and plugs in my car anyway. Let me know what you find
tom |
#29
Will do. |
#30
Well, I had some extra time today and I went ahead and replaced all 6 of my coils with ones I know to be good(from a previous motor). My issue is fixed... thank god because I cannot handle the 10-13mpg I was getting for the past 3 months
tom |
