Old 03-02-2007, 09:09 AM
DarknessofDeath's Avatar
Inhabitant of Darkness
water in exhaust?
i just had to drive through a flooded area to get home and i am wondering what the consequences of water in the exhaust creates. the car still sounds the same..i dont know if any had really gone in, but it's just a question.
thanks for replies
Old 03-02-2007, 09:14 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
DoD,
Just make sure to let the car fully warm up and it should bake any water out of the system.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 03-02-2007, 09:20 AM
I'd be more concerned with water in the intake. If you still have the stock airbox, it dips fairly low inside of the fender. Open your filterbox and inspect the filter and remove any water that you can see in there.
Someone drove my car through a deep puddle once, the filter got so wet that it collapsed, I had to clean sand out of the airtube
Old 03-02-2007, 09:26 AM
cool ~
thanks ~
Old 03-02-2007, 10:15 AM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
I'd say keep the car running and open it up on the freeway to evaporate that water
1995 Subaru Svx L / AWD
Old 03-02-2007, 11:00 AM
dcarrb dcarrb is offline
I doubt much water could make its way into the exhaust, so long as the engine is running. As Hocrest said, it's the other end that would cause trouble.
dcb
Old 03-02-2007, 05:00 PM
It should be fine. I would make sure to run it to get it good and warm so it will get out any water.
Old 03-02-2007, 09:29 PM
i went out for a bit..had to drive here and there...everything seems to be good (still - for now)
Old 03-05-2007, 07:35 AM
Speedklix's Avatar
Locker Link Solution
Doesn't the svx airbox have holes in the bottom for that?
"I had to clean sand out of the airtube "
he better check anyway then... of course, you'd have to know if it got that bad.
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 03-05-2007, 07:51 AM
yeah, you're right. there is a hole in the bottom of the intake box for water
