Rack and pinion problem
Okay, just had a mess up on my Suby. Can anyone with knowledge call me and tell me where I can order a left side rack and pinion for my 92 LSL. Its a freaking long story.
PM for number. Im trying to stay away from the dealer. Id appreciate all the help. Last edited by txferrari; 03-01-2007 at 03:17 PM. |
What??
"LEFT SIDE RACK AND PINION"? The rack and pinion comes as a unit with tie rod ends. While there are component parts, I doubt that you have the expertise to rebuild and in any case the parts are not "left" and "right" except for tie rod ends.
Are you sure it is the steering that is the problem? Is it the rack or the power steering pump? If it is the rack you should look for the entire assembly either on Ebay, from junk yards or Dayle from Motorsports sells them on here. There are two different types--speed sensing and electronically controlled. I would guess that yours is electronically controlled. Lee
SVXx2 92 SVX LS-L Silver 92 SVX LS-L Burgundy (structurally challenged with 2792 miles) 96 SVX LSi Red 92 SVX LS Pearl (Parts) 01 F150 4X4 Red (+6 with other members of the family) FREEDOM IS NOT FREE |
LS~L is electronically controlled
1992 Subaru SVX LS~L Ebony Pearl 1992 Dodge Stealth R/T Firestorm Red 1992 Subaru SVX LS~L Pearl White 1992 Subaru SVX LS~L Ebony Pearl JDM 6MT/DCCD 2007 Subaru Legacy Spec B. Diamond Grey Metallic |
Well, I took it out of the garage yesterday to drive it around since Its been sitting and it started smoking real bad. Took it to the shop, from the top they thought it was a valve cover gasket. Upon further review, once on the lift, they said the left, rack and pinion boot seal was bad and the boot was full of fluid. Which, was causing the smoking. It was driping down on my exhaust and burning off. I did check on Ebay for the pinion set, and found some on the net as well. Just wanted a good connection on the part. I've been seeing them for around $300.
And since Im new, how would I get a hold of Dayle? Thanks.
probobly but you don't want to buy from those guys... They are known as the Slon, vlad...AKA Vineland rip-offs. I have a 97 rack at my shop taking up space... PM me
Tom |
PM sent. Thanks.
Thread Tools | |
Display Modes | |
